Question about Kenwood KDC-C719 10-Disc CD Changer
Cartridge will not reject CD discs - Kenwood KDC-C719 10-Disc CD Changer
Posted by kalexflet on
Anonymous
    New Friend:
  • 4 Answers
I had this when i got one off ebay, take it apart (cover) usually 6 screws, the cartridge inserts may not be aligned inside (part cd sits in) if that is the case you need to remove it/them. it tokk me 40 mins of carefull prise and pull
Posted on Jul 01, 2010
CD ISSUES
Not sure here but try this ,insert a empty cartridge and then turn radio on ,then press reject cartridge and see if one cd magically appears in the cartridge .This normally shows as error 1 and its caused by the battery being disconnected with the cartridge in the player
Apr 17, 2013 | Ford Cars & Trucks
2005 pt cruiser cd player rejects cd and shows err
Either it's a bad CD (format, or scratches), or you have a faulty CD Player. If the CD player is bad, it is likely much cheaper to just buy a new one, than to fix the factory one.
Jun 07, 2012 | 2005 Chrysler PT Cruiser
Rejecting blank discs. roxio will copy a disc then reject the blank disc inserted whatever the format. repetedly asks ----- please insert blank disc.
hi,
You need to update the Roxio program to bypass this problem.
or you can get the the lastest version of the program.
Sep 09, 2010 | Roxio Easy CD & DVD Creator 6...
When I insert a disc into the Tivoli CD player - it immediately shows a message "no disc" and rejects the CD
Ah yes, very annoying problem. I am still searching for the solution and trying not to have nervous break down in the meantime.
May 06, 2010 | Tivoli Model CD CD Player
Getting my computer and cd player to recognise the discs am i using the wrong type of disc? I had problems with my backing up this morning it kept rejecting the disc I tried Kodak 52x cd-r & maxwell...
If it has rejected multiple brands and models of disks (and you are sure the optical unit is fine) then probably your backing system is configured to work in an incremental way, which needs RW disks.
Mar 19, 2010 | HP S3120N Pavilion Slimline Desktop...
Sony RCD-500C I get a data disc message when pressing record.
You need to use CD-R Music or Audio blanks, not Data. It's part of the spec for home CD recorders to reject blank data disks.
Jan 25, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Rejecting cd's
Press the Q/I/ATT and the "sel" button at the same time with the unit off for more than 2 seconds. This will reset the entire unit (you'll have to re-program the memory stations for FM & AM). The disc should eject automatically.
Hope that helps!
Dec 03, 2007 | JVC KD-S640 CD Player
Rejected discs
I had the same problem, with rejections getting more and more frequent. In the end replacing the DVD burners fixed the problem. Apparently, the red lasers that burn the cd surface fade with use. They are still fine reading the disk at low power, but burning at high power becomes progressively more hit-and-miss.
Jan 08, 2007 | Rimage 2000i CDR 2 (52X), CD Duplicator...
Kenwood KDC-C719 10-Disc CD Changer Logo
213 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
