Question about Rolex Day-Date President 118238 Wristwatch
WILL RUN A SHORT TIME THEN STOP
I let it set for two days and it ran down. I set the time and began wearing but it would run a matter of minutes then stop. I can tap it and it starts again.
Posted by roger2717 on
Michael C. De Vito
    Genius:
  • 1,970 Answers
Mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
Posted on Jul 02, 2010
It stops working it will not stay on the correct time
This watch is a self winder and thrives on being used. When fully wound, they should run for 2-3 days and if they run right down then they need to be wound up and used to maintain operation.
I am not sure if this watch can be manually wound but try turning the crown in a clockwise direction. If this is not possible, to wind it up, wave it from side to side for a few minutes (200-300 times) and his should wind it sufficiently to run for a day or so.
Wearing the watch daily is sufficient to keep it going.
Feb 18, 2011 | Rolex Daytona 116520 Wrist Watch
Watch stops shortly after any movement
Automatic, or "self-winding" watches get their power from movement of your wrist throughout the day. Unless you're quite active the amount of movement is just about enough to keep it running till the next day. However, if you let the watch run down completely as you did when you were away, there is no reserve power left. The solution is simple: just manually wind the watch and you'll be good to go. To manually wind the watch unscrew the crown as if you were going to set the watch but do not pull it out as would for setting. Wind the watch about 40-50 turns and it will run fine if you wear it every day.
Apr 10, 2010 | Rolex Mens Airking Watch
Quits running and then starts back
I don't know what the trouble is with your watch. I can tell you every watch I ever owned ran 5 minutes behind. No matter when or where I set it nor how often I set it, within 24 hours, it was 5 minutes behind, never 6, never 4, always 5. After years of questions, I just accepted that my wrist watches would always be 5 minutes behind.
I presume the watch is new ... so cleaning is not a realistic problem. Maybe you should return it to the place you purchased it from and see what they have to offer.
Thanks for your question at FixYa.com
Feb 19, 2010 | Watches
Hi - took it off for 36 hrs - never had an issue - oyster submariner not moving now ... thanks for your help
This is a mechanical auto-wind watch. It self winds when worn. But if taken off for a couple of days it will have stopped and won't start running again unless it is wound.
Put it on and wear it for a few minutes. This will wind it enough to start it running again. Then set the time and wear it and you'll be fine.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 27, 2009 | Rolex Day-Date President 118238 Wristwatch
I just purchased my son a Seiko Divers Automatic 200M watch for graduation. For the first few days, the watch worked, but ran about 15-20 minutes fast. Now it won't move at all? Tried wearing it for 8...
Hi mtrahan99. My advice is to take it back and get it replaced, particularly if you have only had it a few days. If they won't exchange it or refund you, get a repair under the guarantee. Automatic watches (and Seiko actually make some very good ones) don't need to be worn all the time to wind them, and the fact that it ran so fast and has now stopped would indicate something major like problems with the mainspring. Return it! Hope this helps; Eagle58
May 19, 2009 | Seiko Divers Automatic watch
Keeping 2008 breitling cockpit watch running
You have to wind the watch till it is fully wound (significant resistance should be felt).
It doesn't matter how many times you wind it (1 or even 40) - what matters is the strength of the spring.
Do as follows:
At any time in the morning wind the watch up till you feel there is no more winding left (should be quite tough). Memorize the time you did it.
Leave the watch (or wear it) till it stops completely.
Count the hours your watch did work (from the time you wound it).
Now you know exact power reserve for your watch.
It is advised to wind the watch 2-3 hours before the power reserve is gone.
Rate me.
, please.
Apr 08, 2009 | Breitling Navitimer A2332212 G5 431A watch
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Rolex Day-Date President 118238 Wristwatch Logo
434 people viewed this question
Top Rolex Watches Experts
Bruce Robin
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
