Hi, Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open. Thank you !!
Testimonial: "Thanks for advice top already off and washing freed"
Hello. I need the make/model number to help you accurately. Most likely, you have a defective door switch and/or the catch is broken/worn enough so the door isn't held closed properly. Supply the model number and I should be able to provide the part number you need.
I asume this is after the machine has finnished it's wash and all the water has gone.
Door switcheds are a common fault on a washing machine. because they are in circuit all the time. Easy enough to replace. POWER OFF AND PLUG OUT !
With door open, if there is a clip around the front of the door seal then remove it by gently prising it off. Becareful not to damage the door seal. Undo the two screws where the lock is. Where the door lock is located, peel back the door seal enoght to get at the lock and bring it out side of the panel. Make a note of where the wires are and remove them. refit a new lock and replace parts in reverse order.
the door interlock has become worn or has failed
you need to get to the switch from behind
by taking the lid off taking the power off
and reach down to release it
the door interlock has failed and needs replaced
common fault.
look on ebay
but the model number you give is is not right
so i can help you more just now
post the actual model number
and a quick ebay search as .com .uk etc .de
will bring up the part you need
Have you tried to open it when turned off at power. Wait 5 secs after turning off door release should open. If this does not work, put on a wash cycle, start machine then turn off the cycle and switch machine off. Door should open. Failing this I would say door lock mechanism is faulty.
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes * If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
It sounds like the door lock has failed. Call the seller before you do anything as you don't want to invalidate the warranty. You may be able to remove the top of the machine and defeat the interlock which is preventing the door opening from the inside.(REMOVE POWER FIRST)
it could be simply a sticky saftey switch neverless a pain, you could try disconecting the power supply to the machine as the catch is held in a lock state by a current, remove the current and it could reset, if still does not reset this is always hard to explain, but using your fist like a hammer bang the area around the catch as this could free the sticking (still with power off) catch dont bang it hard but it need to be firm use discretion ---post back if more help needed
Hi
Seems like the door switch is failing, or failed.
wpecially if a front loader, the door has to be closed, and register on the circuit as closed before the machine will start.
they are cheap and easy to replace, most of the time, but cant give instructions for an unknown whirlpool other than
take front panel off
replace door switch
replace front panel
you will need to get some help to put the machine near your back door so that you can put the gray hose out side the door when all water is gone your door should open if not then you need to take your pump out and clean it out and then take the filter out it might have a sock or some thing clean it out and buy the time you have put it all back the door should of opened take any thing out of the drum put the machine back and put it on a program so some water can get in the machine then or put it on a rise and spin that will be a good program to put it on if the machine finnish then its all done.
