Question about Lexicon Omega Desktop Computer Recording Studio System
Hello! i've had the lexicon omega audio interafce for a while now and i keep having probelms in sound quality. I use Traktor 3 to DJ with and when i'm mixing i keep getting heavy educed quality in high end where it sounds like it been put through a bit crusher and filtered. I use to be able to stop it when i changed the Driver type but now that doesnt even stop it. has anybody else had the same problem and if so have you found a solution?
Posted by borme65 on
5 Related Answers
Anonymous
SOURCE: Blue Screen of Death when running MIDI input to Lexicon Omega
I tried the above - works perfect!
Thanx lumps...
Thomas
Posted on Feb 07, 2008
Anonymous
SOURCE: My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
Posted on Apr 11, 2008
Robert Hinsman
  • 53 Answers
SOURCE: Lexicon Omega USB on new HP Dual core laptop pc running vista 4GB Ram
You said the magic phrase premiume HOME computer...
and the key word VISTA.
I've heard of VISTA pro running this but the home version is really not that robust for the type of gear you have there.
vista just has to many bugs.
go back to xp pro sp2 for good results.
good luck
44hink
Posted on Jun 12, 2008
Anonymous
  • 3 Answers
SOURCE: Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Posted on Aug 09, 2008
skitney1
SOURCE: lexicon driver
There is a major design flaw with the Omega. The ribbon cable touches one of the power tabs that tends to get very hot. this causes the ribbon cable to melt and damages it.
If you open up the case you will se it straight away.
If it is under warranty take it in to be repaired. It is a simple repair and should cost yo nothing.
Otherwise buy a new ribbon cable (I'm guessing most computer shops would sell them). Rplace the old cable with the new one then insulate the new ribbon cable (with electrical tape or something stronger) where it touches the power tab.
I also drilled a few holes in the top and sides of the case (do this carefully as the case is weak).
Be aware tho that drilling holes or altering the case will void your warranty.
Posted on Feb 24, 2009
Hello i opened my lexicon omega and the cd wont download, i have tried a number of things but it keeps coming up with stienberg softwear, i have registered but the lexicon omega will still not load onto...
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
Apr 16, 2011 | Lexicon Omega Desktop Recording Studio
Request driver for 64 bit Omega lexicon
  • Hello titr_bold, this "Website is the 'Support' for the [LOP Studio], you can go to this site and "Download the Drivers" you need. "I hope this information is helpful? Thanks for using FixYa, paul7of9 " Click here: http://www.lexiconpro.com/downloads.php
Feb 05, 2011 | Lexicon Omega Pro Studio External Sound...
I have a Numark Stealth, DJ IO and Traktor Pro, I want to configure the Traktor Pro so that one can listen to main track on main speakers whilst I cue new track in headphones separately... how do I do...
I want to do the exact same thing. Just got my dj/io in yesterday and I'm not sure how to connect my stealth and laptop to it. U ever figure it out?
Jul 05, 2010 | Numark DJ/iO Sound Card
How I can to installer a sofwer compatible to windows vista? for lexicon omega studio
at first resistering your product. then you download your vista driver on lexicon website; thanks
Apr 09, 2010 | Lexicon Omega Desktop Recording Studio...
Trying to setup Traktor PRO with the DJ IO and Stealth Control as the mixer... cant get the other deck to play on my headphones, and also having trouble figuring out the OUTPUTS in the properties menu of...
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
Mar 06, 2010 | Numark DJ/iO Sound Card
Dj io with Traktor PRO
gvjccçznvcncbdfjcvnmcmxnfbfjgkksdfsd
Jun 30, 2009 | Numark DJ/iO Sound Card
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
Feb 28, 2009 | Lexicon Omega Desktop Computer Recording...
Lexicon omega driver
Yes having the same problem with new driver that Lexicon put on their site 2.5 driver has screwed up everything and the soundcard is nolonger working because of this new driver even their website is down very poor avoid Lexicon Omega
Aug 09, 2008 | Lexicon Omega Pro Studio External Sound...
Phones 1-2 has both channels coming out of it
Had the same problem and fixed it today. It is the mute button. Whem you change from 1-2 to 3-4 if the mute button for 1-2 does not activate you will get the sound from 1-2 thru 3-4. Just change the setting and you are away. worked for me.
bruce
Jun 03, 2008 | Echo Indigo DJ Sound Card
Lexicon Omega Desktop Computer Recording Studio System Logo
103 people viewed this question
Top Lexicon Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
