Question about Uniden Cordless Phone
Uniden XDECT 7055 hand set problem
Hi
I have just purchased a Uniden XDECT 7055 dual phone and I am having problems with the extra hand set. The main phone has been wall mounted and is working fine. The hand set is fully charged but just says "searching" and none of the other buttons work. I am aware I have to register the phone to the base but the phone seems to be completely dead other than the "searching' message. It was suggested I take out the batteries for 10 mins which I did for a few hours and then tried again. No joy...please help me as I am at a loss. thanks
    New Friend:
Hope this is solved for you. If not, I found the connection for the battery a little temperamental and had to play with it a bit before the connection worked properly
Posted on Jan 16, 2011
6ya staff
SOURCE:
My Uniden xdect 7055 is not working since NBN was connected. Is it compatible with NBN?
I have a uniden detc 6.0 system and it works with NBN
however you have to have the base unit connected directly into the modem and the land line connected into a different port in the modem
call your service provider and get a diagram of connecting items to the NBN modem
Jun 27, 2018 | Uniden Lands Phones
Radio shack 43-113 cordless phone
Re: "compatible extension hand set"
Have you tried Uniden DXI-986-2 900 MHz Cordless Phone with Dual Handsets and Extra Charging Cradle. You would have to disable the base of the main unit of the Uniden and simply use it as a cradle/charger. Additionally, it may be to your advantage to bring along your Radio Shack Hand set when trying/buying the Uniden to see it they will pair up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 22, 2008 | Radio Shack 433575 Cordless Phone
I bought my Uniden phone XDECT 8155e - home phone two years ago currently the phone hand sets are flashing for the last few weeks please assist?
As this is a mobile phone, more people on the forum dealing with such equipment are likely to be able to help you.
Jun 29, 2017 | Cameras
How do I setup a Uniden Dect 5.8Ghz 8155+2 phone
Uniden XDECT 8155 + 2 Questions & Answers ...
www.productreview.com.au > ... > Uniden > Uniden XDECT 81xx Series
Uniden XDECT 8155 + 2: 25 questions and 38 answers on Australia's largest opinion ...and select Handset Setup or Base Setup. ... If you have a 2.4 ghz or 5.8 ghz modelphone use web address below. .... Uniden Premium DECT 31xx Series.
Nov 23, 2015 | Uniden Lands Phones
How do i set my time on my cordless phone uniden xdect extended digital 7055
Follow the instructions on page 10 of this manual: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_7055_OM.pdf
Also, in the future please do not post your question as a "solution" to someone else's question.
Sep 19, 2013 | Lands Phones
My uniden xdect sse25 cordless doesn't ring for long enough before diverting to the answer machine I have mobility problems how can i extend the length of the ring
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
The manual for the XDECT SSE25 is available from Uniden here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_SSE25_OM.pdf . See page 19 (23 of the PDF). You will need Adobe Reader to access the manual.
I hope this helps.
Jan 25, 2013 | Uniden Cordless Phone
Setting date & Time on XDECT 7055
I have the same problem. The up and down keys just adjust the volume of the phone. I can't change the day and time. Help.
May 24, 2010 | Uniden Cordless Phone
How to set date and time for uniden model XDECT 7055 + 1
you have to do it from the hand set, go into menu, using the arrows scroll down to date and time , use the arrows to select date , then hit select do the same for the time, then when the am option flashes use arrows then select , then its done , hope this helps
Dec 14, 2009 | Uniden Cordless Phone
Recently bought uniden xdect 7055 plus two cordless & i have spent 2 hours trying to get to work but no such luck - seem i have to register my ID with telstra before they will connect me to my telstra...
The manual does not make it clear that you have to set the day/date/time option on the handpiece - not on the base unit (which you would think was the logical place).
The base unit has only three options under its menu (see page 9 of the Owner's Manual).
See pages 9 and 10 of the Owner's Manual.
Dec 13, 2009 | Uniden Cordless Phone
Uniden Cordless Phone Logo
777 people viewed this question
Top Uniden Lands Phones Experts
Marvin
Marvin
martin hogg
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
