Hi have you tried adjusting the tint , ntsc tint?adjusts the red-green color balance in the image of NTSC video images. The tint setting applies to NTSC video sources only try adjusting this this may help....
what this indicate from the color display on the system mean that the display sensor (lens)in getting weak it need servicing or a replacement, to to this servicing you will have to unscrew (open) from the stroll then clean up the lens with little spirit solution on the surface with care allow the solution to dry up it self then reset the programming on it please while doing this you will have to be very careful with the wire connection around ,but if this fail then you will have to get a replacement on it
This are recommended fix is to replace the lens. You can generally find replacement parts at these websites:
www.projector.com
letsgodigital.org
comforu.com
technabob.com
techshout.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing a lens is not a difficult repair and can be accomplished by
the average do-it-your self offer. If you decide to order the part and wish
to repair this on your own
thank you and thanks for you sing fixya.
I don't understand the instructions about how to service the lens. When I hear lens, I think the glass lens of a camera or projector, but it appears the display is something else and can be serviced. I simply can't understand the message from ms-shop. Can anyone else explain how the lense is making everything appear yellow all of a sudden??
