Question about Ricoh IS760D Flatbed Scanner
I have a problem with the ricoh is760d to scan to a Windows 2008 share thanx
Posted by paul_koopman on
2 Related Answers
Anonymous
  • 121 Answers
SOURCE: Ricoh IS760D
go into your properties by right clicking on the icon or goto my computer, look for your printer and right click to find property setttings.. you should be able to adjust your colors from one of the tabs that appear..d
Posted on Feb 22, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Ricoh IS760D Functional Problem SC4020
Unfortunately, the message indicates that the internal startup tests have failed. If this unit is just past the warranty period, I would contact the manufacturer anyway and complain. No unit should fail that close to the period conclusion especially with little to no use. It is possible that a brown-out may have damaged the internal logic. Only a service tech for the company could tell you that. The blinking lights are an indication of the problem found. Report that to the company as well.
Good luck. Keep us posted.
Dan
Posted on Mar 18, 2008
How do i setup scanner from my machine to my laptop? please start from step 1 including cable connectios and scan to folder instructions. I am using windows 8.1 pro
Before you even start, your machines "Network Support" firmware needs to be up to date to be able to connect to a Windows 8.1 PC.
Secondly your machine has to be networked. No USB scanning supported on Ricoh Devices. Create a shared folder on your C: drive called "scans". Share so "everyone" can access the folder. On the MP2852 select scanner mode and tap the block with "Prg Dest" on the screen. Select Folder and Browse for your PC. Enter your PC Username and Password when asked. Find your shared "scans" folder, select it and then tap OK on the screen. Next enter your name and save. You should be good to go. Keep in mind anti-virus and firewalls can block it. Also ensure your PC is part of a "Home Group" otherwise you will not find your PC when you browse from the MP2852. If your PC is not in a "Home Group" then you can just create a "Home Group" under your "Network and Sharing Center" and while you are there ensure that "Password Protected Sharing" is switched off under your "Advanced Sharing Settings" also found in your "Network and Sharing Center".
May 28, 2016 | Ricoh Aficio Mp 2852 B&w Copier
Ricoh IS760D won't work with Windows 7 64-bit
Software (driver) can be found at driverupdate us.
Take a look... I hope this was helpful.
Cheers
Jun 27, 2012 | Ricoh IS760D Flatbed Scanner
Black line on right when scanning adf - have cleaned the machine dont know what else to do
If line appear in to your scanner pic no repair for that but is only when you print just clean the toner.
scanner Lents cant be change
Dec 17, 2010 | Ricoh IS760D Flatbed Scanner
Scannning too slowly
Increasing the default resolution setting, would slow the scanner down, and also increase file sizes dramatically
Feb 18, 2009 | Ricoh IS760D Flatbed Scanner
Richo color scanner is760d don't have option auto feeder
This scanner can be controlled by PixEdit so you may scan any amount of sheets. Even easy continue scanning to one document when not enough space in the ADF for the hold stack
Dec 08, 2008 | Ricoh IS760D Flatbed Scanner
Dan
Mar 18, 2008 | Ricoh IS760D Flatbed Scanner
Ricoh IS760D
Feb 22, 2008 | Ricoh IS760D Flatbed Scanner
Ricoh IS760D Flatbed Scanner Logo
61 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
