Question about Laser Canon imageCLASS 8180C Multifunction Printer
Canon LBP5200 displaying Error Code E078 What is the problem?
Posted by edhystek on
Anonymous
  • 1,219 Answers
E078 secondary transfer roller drive
mechanism fault
Possiblle causes:
Check the connector of the roller drive sensor.
Check the connector of the roller drive clutch.
Replace the main drive assembly (roller Drive
sensor).
Replace the drum cartridge (roller drive cam).
Replace the DC controller PCB.
Posted on Jul 01, 2010
Canon laser shot lbp9100 CDN error code 78-0001
E078 - Error in detecting HP of ITB cleaner (Error in failure of detecting HP (pressure) of cleaner unit of transfer belt)
0001 - The HP sensor does not go on within 5 sec after the start of a HP search.
Jan 03, 2017 | Canon Office Equipment & Supplies
Canon lbp5200 64 bits windows driver
You may download the LBP5200-series drivers and software from here.
Sep 13, 2012 | Canon LBP5200
Will a canon LBP5200 run on windows 7
Yes
Just try this Link for windows 7 Drivers
http://software.canon-europe.com/products/0010175.asp
Apr 16, 2011 | Office Equipment & Supplies
Error Code: E078
i change tone come error e 78
Dec 27, 2010 | Canon LASER SHOT LBP-5200 Printer
Error message E078 on Canon MF 8100 series after replacing drum
try to check your connection form your printer and if possible try reinstall the printer driver then try to run again the printer.
Jun 16, 2009 | Laser Canon imageCLASS 8180C Multifunction...
Error E078 Canon MF8180c
I have a Canon Color Image Class MF 8180C with a system error code E078 - Trying to understand what it means and how to clear. Any ideas?
Jun 05, 2009 | Laser Canon imageCLASS 8180C Multifunction...
My canon LBP5200 does all the usual whirring and stuff as if its about to print, when the paper feed normally starts instead the alarm light flashes and the following shows on screen :- Printer error....
The fuser unit is faulty.It sits at the back of the printer and disconnects by unlocking 2 blue levers.reseat it and try again,if not you need a new fuser
Aug 06, 2008 | Office Equipment & Supplies
Laser Canon imageCLASS 8180C Multifunction Printer Logo
Top Laser Office Equipment & Supplies Experts
efs_perpends
efs_perpends
ADMIN Canada
ADMIN Canada
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
