Yes there should be a water level sensor on it,it either is a small one surface mounted onto a board/timer or seperate,if its seperate you can usually blow into them and here a click or double or treble click depending on the amount of levels on the machine,you can double check switch with a multimeter when you blow into switch,with the switch removed of course.If it spins and washes ok its probably the timer.You can check spinning by dropping hose at spin on timer.
