Question about Xerox Office Equipment & Supplies
Xerox 5837 Diagram, Fault Codes, Service Manual ??
I just purchased a Xerox 5837 copier for my local volunteer fire department and while transporting it something happened .. I called up customer service at Xerox but since we don't have a service contact they wouldn't give me any idea how to correct our problem ..
Fault Code 06-430
I would love to get my hands on a Xerox 5837 diagram, fault code sheet, and service manual but most of all I would like to fix our current situation .. all customer service would say is that it is an optical system error.
Any help would be greatly appreciated .. since I am not a techy guy very specific instructions on how to fix this issue will be important.
Thanks, Don Roach President - Fire District Board of Trustees
  • 2 more comments
  • Anonymous Jul 01, 2010
    Could someone please give me specific instructions on corrective actions relevant to Fault Code 06-340 ..
    Thanks
    I am a nobody when it comes to copier repair; however, I do know that the closest Xerox repair person is probably more then 40 miles from my location and the fire department can't afford to pay the repair bill for a service call anyways .. any and all help will be greatly appreciated !!!
    Help please ..
    these are great tips but without knowing what any of these things are I can't do anything ..
  • 239 Answers
This problem can be expensive repair bill.
The optics motor can be bad or the small belt might be broke. Even if you replaced the motor there are other areas in diagnostics that need to be changed. A bad driver control board can cause these problems, along with some connector on the boards; they need to be re-seated.(Unplug the jacks and replug them, all) The error codes need to be removed before the machine can start. There are manuals and charts that shows the different configurations of models, these codes need to entered to the correct values with the right machine model.
A full sump bottle can cause the problem. Over or under exposed copies can shut the machine down. A old NVM chip with a old battery can have corrupted memory causing many error codes.
This machine has been out in the field for sometime, and is not a new machine. It has time against it. Rubber materials degrade in time. Plastic parts brittle and break especially around the fuser areas.
Best thing to do is, maybe call the Xerox sales person and trade this machine in for a new one. Make a good investment. Good luck.
Posted on Aug 06, 2010
  • 2,567 Answers
1. Remove the glass plateform
2. Check the exposure lamp continuity, if no continuity replace it.
3. Check the exposure thermos fuse continuity, if no continuity replace it.
Posted on Jul 01, 2010
  • 857 Answers
Follow the steps below to resolve your problem:
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
    President:
  • 1,194 Answers
The control logic sensed an error in the self test routines of the IISS PWB Ram test (06-340).
Initial action:
  • Switch off the machine power.
  • If there is other equipment close by that may be generating electrical noise or radio frequency interference, power it off also.
  • Contact Building Maintenance and have them verify the proper voltage at the machine plug.
  • Clean and inspect all corotrons for defects and ensure they are properly installed.
  • Power the machine on.
If the problem still exists:
Place a service call.
Thanks for using Fixya.
Good luck and have a nice day
  • 3,083 Answers
I couldn't find your exact manual, but I found some that will be close. Manuals are like cars- same basic operation, different options. What I suspect happened is that the copier bulb assembly moved during transport, and some gears that drive it are locked up. Not an easy problem to fix, or reset, since there will be a slight disassembly process to reseat everything, without stripping a driving gear. This isn't going to be a job for the everyday mechanic, and you will need the service manual to do it correctly.
You can take a shot at a manual close in number, to the model you have, and maybe you'll have a chance of fixing it. I read in another blog that the 5837 is the 5340 style. Here's the manual link:
http://www.nodevice.com/manual/Xerox.html
Not sure if there is a cost, since I've never downloaded from this site.
Also, you might try to download this .pdf service manual. My Adobe's not working right since Windows updated it, but here's the link:
www.pdfound.com/pdf/xerox-5855-service-manual.html
Good luck, and hope this helps.
    The first link is a pay site and the second was one that GodBlessU posted with the first solution ..
    Thanks so much for trying but I'm gonna guess I'm gonna have to keep looking since I have no idea where any of the parts you mentioned are located on the copier at all :(
    Brigadier General:
  • 3,513 Answers
Please find the fault code sheet here:
http://www.office.xerox.com/userdoc/P750/resource/750-66.html
and
http://www.partsdrop.com/techinfo/enx_5340cop.pdf
http://www.xerox.com/digital-printing/site-map/copiers-old/2/enus.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jun 30, 2010
    Thanks for the second link above, I couldn't get any relevant info from the other two but it is greatly appreciated. You said the fault codes were on the first link and I couldn't connect the two as it was for a phaser printer.
    Can you tell me how the fault code 06-340 can be corrected? Customer service said it was an optical issue .. I figure there is just something that needs cleaned because it was moved and old toner probably got on something. If I had a diagram I might find where all of the optical places could be found.
Anonymous
SOURCE:
Have a fault code 52 on my 2009 vulcan classic 900,stick coil malfunction, runs good then the fi light comes on runs bad,goes out runs good,how do i repair the problem and is that what it really is,,
Hi, John for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
new ecu installed now have error codes
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/133076-vn900-ecu-fault-codes.html
KAWASAKI VN900 CLASSIC Service Manual
http://mybikemanuals.com/kawasaki/kawasaki-vulcan-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 19, 2016 | Motorcycles
I have BMW FGS 650 2009 model but bike is injecting and the fire is not stable that my fault
Hi Vijay, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
Sep 30, 2015 | BMW Motorcycles
Xerox 1000 print engine fault codes 42-334 & 42-335
You can google this information or call customer service from xerox
Jan 11, 2014 | Office Equipment & Supplies
Boxer bike electrical wiring diagram
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.Boxer bike electrical wiring diagram Google Search
The Boxer Wiring Diagram
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Oct 03, 2013 | Bajaj Motorcycles
Xerox 425dc service code
Hi.
The 425 dc error code refers to the department code assigned to the printer.
425 means that you have entered an invalid department code.
to fix this, you need to turn off the department codes
To do this, press the menu button so that it says machine defaults
then use the arrow down scroll button until you get department codes, then press enter
Scroll down to select off, and then press enter again.
Now press the features button to return the printer to a ready state.
You should now be able to print on the copier again.
I hope this helps you out.
Feb 08, 2011 | Xerox WorkCentre Pro 416Pi All-In-One...
Xerox 5837 Fault Code 06-305 I can't find this code anywhere and all it says when I push the i (info) button is "Call Service Technician" .. which would be ok, but we are 50+ miles from the nearest...
Hi Donnie,
The code 06-305 for Xerox 5837 means "Exposure Carriage Registration Sensor" fault.
You can download the document which explain the codes from this link which I uploaded for you.
Hope this helps.
Kind Regards.
Jul 02, 2010 | Office Equipment & Supplies
When in the MO mode, I hear nothing. In the FM mode, I hear everything. I want just to listen to local FD. I have their codes loaded in. Just doesn't seem to scan the channels when in MO. What am I doing...
MO is for monitoring MOtorola trunking systems and will only work if you have programmed a system into your scanner. Most fire departments are using conventional, (FM) transmissions, not trunked systems - mainly so that volunteers and neighboring departments can follow the action and respond if needed. For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Need the manual for your scanner? You can download and print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
Bill B
Feb 21, 2010 | Radio Shack Pro-96 Scanner
Need part #'s for pick and feed rollers for all trays on a Xerox Copier 5837
Google a business called "the parts drop". Look it up there or call Britt.
I do not work there. Just do business with them. Top notch service and fair prices.
Jun 17, 2009 | Xerox Office Equipment & Supplies
Xerox 5837 with 08-310 Error
If you donot find paper in the machine check for a stuck actuator or a bad sensor.
Jun 03, 2008 | Xerox 5830 Copier
577 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
