Depending on where you live, you would need another
200.00 to buy the freon and another 60.00 to buy the
refrigerant gauges.
Turn the unit off outside, turn your thermostat all the way to cool and as low as it will go. Go back outside
and turn the power back on, The condensor fan and the compressor should both be on.
If neither one is on, or one is and one is not then 40.00 might be able to buy you a hard start kit
40$ might buy you a few minutes of a certified tech to tell you what you really need. Only he should be putting in freon...and only after a leak was looked for and found. Other than that freon shouldn't be low.
