Homedics FOOT MASSAGER ULTRA DEEP KNEADING FOOT MASSAGER WITH HEAT FOR TIRED FEET. GREAT GIFT FOR ANYONE! 2 Year Warranty Logo
Posted on Jun 30, 2010
I wan to use in office work - Homedics FOOT MASSAGER ULTRA DEEP KNEADING FOOT MASSAGER WITH HEAT FOR TIRED FEET. GREAT GIFT FOR ANYONE! 2 Year Warranty
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Jul 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
4371
Points
39
Place it in a bag. Take it to work. Plug it in. Enjoy.
1helpful
How to reset the password of the 3CR858-91 router? because I don't know the password.
the default user name is admin, try that with no password.
if that doesn't work to reset it you
1- Power OFF your router.
2- Disconnect all LAN cables
3- Loop the WAN port to a LAN port, in other words hook up a network cable from the WAN port to one
of the LAN ports
4- Power up, wait 15 seconds
when you have done that use the default username and password to access the router, but when you have done this make sure you set a new user name and password and keep it somewhere safe.
Robert
I haven`t MS office on my computer and I wan`t to download free. But I can`t find on the Internet or Google Do you know where I can dowload MS Office FREE.PLS HELP
MS Office is not availabe for free download on the internet
You will have to buy it
If You need a freeware you can download Open Office
it is not as same as MS office 2007 but will work
What is theam.if we apply theam the wole appreance will change or only on desktop
How Can One Cable Modem Work With Two Wireless Routers? By Terry Stockdale Leave a Comment In How to Fry a Wireless Router or Two, I wrote about my brother's experience frying a pair of wireless modems in a lightning storm. Last week, I talked about what had happened, why it happened, and what he could do to prevent the problem in the future (this was the third set of routers, plus he lost a computer motherboard in that storm).
This week, we'll look at his network layout, and why he could not get the network to set up properly.
To summarize the situation, he has an office an a shop, with computers on his network in both locations. Some connect via wired connections (Ethernet), while others use wireless connections. His Internet cable comes into the office first.
In the past, he first used Linksys wireless routers. Then DLinks. This time, he chose Belkin wireless routers.
The incoming cable (standard cable-company RG6 coaxial cable) connects to the cable modem.
Then, the cable modem connects to the WAN (wide area network "Internet") connection on the router.
The local wired ports on the router provide connections for two wired computers. Notebooks connect via wireless connections. Finally, one wired connection on the router is used to connect an Ethernet cable that runs 250 feed to the office from the shop.
That cable was the lightning problem, as it runs outside in a conduit just a little bit underground. Effectively, he's got a 250 foot antenna looking for the electromagnetic pulse from a lightning strike. Most of us don't worry about that because our equipment is so well grounded in the house, plus the Ethernet cables we use are much shorter lines. Even if we have underground cable company lines running from their switch boxes to our houses, those lines are usually only exposed about 40 to 50 feet before they enter the dwellings.
Back to the situation. When he hooked up his replacement routers, the router at the shop immediately worked. Not so, on the router in the office. The Ethernet light and the Activity light just poounded away, blinking and blinking rapidly. But, nothing connecting to the router could get to the Internet.
If they connected a computer directly to the Ethernet cable in the office, without running it into the router first, it worked just fine. But, with the router in place, it didn't work.
The problem was the way he connected the two routers. The problem is that there is no Out Of The Box connection that will work reliably. At least one thing, usually two, has/have to be tweaked one way or another.
As one might guess, the easiest way to connect would be to connect one router's WAN connector to the cable modem, using Ethernet cable, and then use Ethernet cable to connect one of the Local Area Network (LAN) connectors on that router ot the WAN router on the other computer.
There is a problem with this setup, but it's easily solved. First, if you're using identical wireless routers, as he was, the wireless routers are both trying to use the same IP Address range and subnet mask for their local area networks.
That works fine for the first router, which is connected to cable modem. On the cable modem side, it gets an IP address on the Internet Service Provider's network - often an actual Internet address and not just a private network address. On the local area network, it assigns the IP address range specified in its setup menu. This often varies by manufacturer. In the case of Linksys, this is 192.168.1.x. In the case of the Belkin routers he bought, it was 192.168.2.x.
The problem occurs at the second router. On it's WAN side, it sees a 192.168.2.x network - but it's default setting tells it to give 192.168.2.x addresses on it's local area network side, too. In other words - it's confused. It doesn't know where to find the Internet because both networks are assigned the same addresses.
The solution was to disconnect the second router's WAN/Internet cable, connect to it via a wired computer, and tell the second router to use a different IP address range. We chose 192.168.3.x.
We hooked up the Ethernet cable to the Internet/WAN side of the router again. The router started working fine, normal light blinks for activity, no more confusion. The computers could get to the Internet just fine.
Problem solved.
That solved the Internet connection problem. However, no computers in the office would be able to share files or printers with the shop, nor would computers in the shop be able to share with the office. That was both acceptable and intended, in this case.
It could be done; however, that would require a different configuration on the routers and connections.
I wan,t to download microsoft office
If you have the money just go to the Microsoft site and buy it.
If you don't then get   http://www.openoffice.org/   for free.
I have only power and ehternet led glowing in my DNA-A211-I bsnl modem....when i checked with the BSNL office they told everything is fine from their side......is it a hardware prob...or the reset pin wil...
-First i would test the Internet, by plugging the cord from your BSNLmodem directly into your computer, restart your computer. If the internet works you know you have a problem with router.
-Next unplug your power from the router and then plug your cord from the BSNLmodem back into the Internet port or WAN port of your router. Now plug the power back into your router. This should reset the WAN IP in the router, if that does not work. Try the reset PIN.
If that does not word you could try reflashing the firmware and if that does not work then I would say its Hardware.
Cheers, let me know if you have any questions.
I bought a TrippLite Internet Office UPS surge protector in January 2009. I have misplaced the manual. Recently it began to beep for no reason. There is no power failure. It was so annoying I had to unplug...
this unit come with 4 with battery backup of 12v 7ah. check what are the indicator display shown?
it very diffcult know what the problem if u can give more info. u can try to replace the battery with new batts.. and test the ups if it not beeping again it show the battery problem. or maybe you had plug in more the the power consumtion that why it keep sound the alarm indication overload try to serperate the load. if u wan a user manual go to this website to download the manual: http://es.tripplite.com/support/manuals/index.cfm
u will get will u wan...
Can't intall and run MS Word app
If you need to be able to use spell check in Outlook Express Please download the spell checker from here and install it you are good to go.
I am adding a new deskstop to my house, so a friend gave me his belkin router. i have been trying to set it up, but the problem is i have qwest choice internet and my modem is in my cable box in my master...
Wat u do is to just Connect ur Telephone wire to modem as usual and the output of modem has to be given to WAN port of ur router. your router must have atleast 2,3 LAN ports, take output from those ports and connect it to ur both desktop pc's...
No wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Top Homedics Health & Beauty Experts
jws1013
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
