Question about Canon PC170 Copier
Prints letters blurry as if you pass the brush.
My copier prints letters blurry half of the leaf, the other half prints correctly, the fuser rollers are in good condition, just as the drum roll what can be? Thanks
Posted by aislas8a on
Canon tech CROATIA
  • 1,219 Answers
How blurry? Like toner can be wiped of or like the letters are verry light?
Did you check pressure between fixing and pressure roller, it could be the bad bushing that causes the problem.
If they are very light, clean optics.
Posted on Jul 01, 2010
4 wide horizontal blurry lines in printed document
Either sensitive drum of the tonner is damaged or the high temperature fuser roller damaged. Check and replace.
Nov 17, 2015 | Brother DCP-7020 Laser Multifunction...
Throughout print job HP laserjet 9050 print will be squigly/flakey and not fuse to paper properly
when you replaced the maintenance kit - did you replace the Fuser assembly as well - as this faultr is down to the pressure off the fuser roller to fix the image also there are two blue tabs that set the fuser unit to letter mode(less Pressure) these can be accessed without removing the fuser and are accessible from the left door. ensure the levers are set to paper and not letter. if the fuser is still not fixing the image correctly then a new fuser unit assembly is required as fuser units are non servicable.
Jan 08, 2014 | HP LaserJet 9050 Printer
When I print with my brother hl-2070n...the print out is very very faint. i have changed the toner and drum...any suggestions?
if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
Mar 12, 2013 | Brother HL-2070N Laser Printer
Hp 5550dn prints text fine but pictures are blurry?
Don't replace but verify the condition of fuser assembly, if you found any cracks or folds on teflon roller or pressure roller causes the same thing, just verify get back to us...
Feb 01, 2012 | HP LaserJet 5550DN Printer
My CLP 315: starts printing, but paper jams every time. It's prints fine on the top half of the page, then gets blurry and will not exit printer. I have to turn off/on to get the page out. I...
at the fuser unit. thes is the part were the printer get very hot with a red and gray roller.
look in th sid of it you will find a sensor . you need to replace it
Jul 24, 2011 | Samsung CLP 315 Laser Printer
Imprime letras borrosas como si se le pasara la brocha.
Do you mean blurry, like toner isn baked, or ...
If yes, dispite the good conditions of fixing roller, you may want to replace bushings of fixing rollers too. Because they do not generate enough pressure.
Jun 30, 2010 | Canon PC170 Copier
I have HP Laser Jet 1020 When I print letters
Most cases on that machine it's the transfer roller that does that at 75mm, but could also be drum cartridge or fuser. Use a flashlight and inspect the fuser, shouldn't be toner or image on fuser rollers, If you unplug the machine when the print is in the middle, you can tell if it's before or after the fuser, and after the drum.
Nov 24, 2009 | HP LaserJet 1020 Printer
Print smear
It might be the fuser that is defect. perform a half paper path test. Let the paper get pulled in for half of it's length and open the cartridge door so printer stops, check the paper and see if issue is on the out print before passing the fuser. Also check that you have the power cord directly to wall socket and not using an extension cable that may reduce the current to the printer. Another tip can be to change paper type in the printing preferences to a heavier type ex. card stock wich have the printer to work slower.
Oct 15, 2008 | HP LaserJet 1100 Printer
Xerox 416si print or copy are dirty
the problem is upper heat roller of the fusing unit are defective.try to ask xerox u.s.a if you can buy only the upper heat roller.
Apr 14, 2008 | Office Equipment & Supplies
OKI c3200 Laser Printer...
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Apr 07, 2008 | OKI C3200n Led Printer
Canon PC170 Copier Logo
387 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
