Question about Canon PC170 Copier
Imprime letras borrosas como si se le pasara la brocha.
My copier prints letters blurry half of the leaf, the other half prints correctly, the fuser rollers are in good condition, just as the drum roll what can be? Thanks
Posted by aislas8a on
Canon tech CROATIA
  • 1,219 Answers
Do you mean blurry, like toner isn baked, or ...
If yes, dispite the good conditions of fixing roller, you may want to replace bushings of fixing rollers too. Because they do not generate enough pressure.
Posted on Jul 06, 2010
Mi problema es con mi mi televisor mitsubishi vs-50501 enciende y cuando va a entrar la imagen se apaga a veces si entra y se ve medio rara como que tiene dos imagenes un poco separada o se ve la imagen...
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Dec 19, 2013 | Mitsubishi VS-50609 50" Rear Projection...
No speak english only spanich.. simpletech 500gb pininfarina problems light red I can not see the content
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the USB. If you received a cable with a split dual USB plug for extra power make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Escuche atentamente a la unidad, si suena como que est? haciendo clic a continuaci?n, es probable que no reciba suficiente energ?a el?ctrica a trav?s del USB. Si usted recibi? un cable con un enchufe de divisi?n dual USB para la energ?a adicional asegurarse de que los dos grandes puertos USB en el ordenador mientras el m?s peque?o es conectado a la unidad, esto le dar? la energ?a suficiente para empezar a trabajar. Si no es hacer clic y tiene un mont?n de energ?a, entonces podr?a ser que se asigna a una letra de unidad que ya est? en uso. El Administrador de dispositivos (clic derecho en Mi PC y seleccione Administrar continuaci?n, haga clic en Administraci?n de discos) Si usted ve el dispositivo en el que se puede hacer clic derecho en la representaci?n gr?fica de barras del disco y seleccionar a cambiar letra de unidad y rutas. Esto le permitir? eliminar el conflicto y que se muestre de nuevo.
Jul 06, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Tengo una impresora cannon mx 320 La impresora no imprime y me da el siguiente aviso en pantalla; ERROR DE IMPRESORA 5200
tengo canon mx320 y no imprime correctamente si es una linea recta sale torcida las letras tambien que puedo hacer
Feb 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Bonjour, j'ai un problème avec ma MP600. Elle n'imprime plus en noir. Pourtant lorsque je lance une impression noir et blanc elle fonctionne comme si elle imprimait, mais à la sortie, la feuille...
English to French translation bonjour il se pourrait que votre t?te sur votre imprimante est bloqu? aller ? la maintenance de votre imprimante et faire le nettoyage de vos t?tes dans la partie maintenance de votre imprimante, il vous dira everthing comment le faire
Oct 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Prints letters blurry as if you pass the brush.
How blurry? Like toner can be wiped of or like the letters are verry light?
Did you check pressure between fixing and pressure roller, it could be the bad bushing that causes the problem.
If they are very light, clean optics.
Jun 30, 2010 | Canon PC170 Copier
Mi nevera no esta enfriando en el lado del refrigerador
cambiale tambien el bimetalico y la resistencia tambien podria ser le desconectas los 2 cables de lado a lado de la resistencia que esta en el freezer y le pones un cable 110 y lo conectas si ve que se pone caliente la misma esta buena pero si no puede ser parte del problema , cuando estos problemas pasan hay que buscar en el timer,bimetal y resistencia
Feb 23, 2010 | Frigidaire FRS26R4A Side by Side...
Como configuro la copiadora impresora canon ir 1023
tiene que ser una 1023 con habilidad para imprimir. aunque no lo creas no todas las 1023 imprimen. si la tuya si imprime no debes tener mayor problema al conectarla via usb debe detectarla windows y se instala como una impresora cualquiera. ojo, el hecho que tenga puerto usb no quiere decir que sea impresora.
Sep 10, 2008 | Office Equipment & Supplies
Como cambiar la lampara
si ves la tv por el frente tienes que quitar el grill the las vocinas, es muy facil, agarra el grill y hala hacia afuera, solo tiene unos clips,luego mira hacia la parte central de la tv y veras unas letras negras y tiene la informacion de la lampara.hay 3 tornillos que tienes que quitar(desarmador philips) luego veras la lampara nesecitas un desarmador plano y son otros 3 tornillos.aflojalos y hala la lampara hacia afuera.luego installa la lampara nueva haciendo el proceso alreves. hacegurate de poner el covertor de la lampara antes de encender el televisor. y si te pregunta si cambiaste la lampara preciona enter(cuando enciende la tv en letras en la pantalla.. buena suerte .
hdtvman.
Jul 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Canon PC170 Copier Logo
95 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
