E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
When installing toner for the 1st time on the IR2520 you need to do the following.
Go into service mode
Go to CLEAR
Do a ALL CLEAR
Switch machine off and back on again.
Set DATE/TIME ect.
Go back into SERVICE MODE
Go to CLEAR
Then ENGIN and press OK
Then T R –install.
This procedure can be used if iR2520 gives a toner problem
e.g. the dev unit does not have the right amount of toner and
copying is suspended during use.
Hi i hv ir2520 panel blank .when take out other machine main board .fix to the problem machice come code E335.anyone can help me how to sovle this problem?
Write your answer...copy only 2 paper then stop
And what is the admin code?
SOURCE: The copier is canon,image runner
e000020 is error with toner unit,
several possibility :
- The toner is empty
- The developer failsto be replenished with starter developer properly.
- Related developing unit
- Ahopper motor error is identified by the detail code of E020. However, it may be identified by E02x according to need.
