The LG error code OE simply means “the pump is blocked”. Presumably the
water isn’t being emptied properly.A pump, or filter blockage is the most common cause but it could be
caused by other faults such as a faulty pump, or even a blockage in the
drain hose or somewhere else in the system etc.
Clean and straighten the drain hose / clean the drain filter.
SOURCE: lg washer oe code pump pluged
open panel small door on left front panel. empty water and clear pump.
