Question about Linksys WRT160N Wireless Router
My linksys wrt160n wireless router light is blinking
Posted by mediatracken on
shafi
    President:
  • 1,070 Answers
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Posted on Jun 30, 2010
  • shafi
    shafi Jun 30, 2010
    Still have any Problem for your Router Make a Reset....Keep Using...
5 Related Answers
Anonymous
SOURCE: linksys wrt160n wireless router
how can i connect my router so that i can use my laptop
Posted on Sep 29, 2008
KingDWS
Dave King
  • 1606 Answers
SOURCE: weak wireless signal - WRT160N is a piece of trash
We found Linksys wifi units to be unusable a few years ago. I had a stack of them that the wifi had died or was unstable or short ranged and none of these were more than a year old. They have had quality problems for about 5 years. Tech support is handled overseas and consists of them reading off of cheat cards. If you get through to a tech you will find them not to understand any technical jargon and once not even normal non technical english.
Our "fix" (and what I'd reccomend if you want to avoidl headaches) was to yank out all remaining Linksys units and replace with a different brand. We didn't see any difference with the models, they all failed in some way. I don't know what happened to the company but they used to have a very good product. They don't have that now.
Posted on Sep 12, 2009
A Miller
  • 8404 Answers
SOURCE: Cannot connect wirelessly to my Linksys WRT160n, but wired works
Get Network Magic ... download for evaluation.
This is a tremendous network management tool well worth the $. If you dont pay, you can still use most features.
Get it and use it to get your connection going at least.
Let me know what happens
a
Posted on Oct 01, 2009
dongkikz
Ferdinand Ecuacion
  • 440 Answers
SOURCE: Linksys WRT160n V2 Wireless-N broadband router was
Try hard resetting it for 1 minute to 2 minutes ; press and hold the reset button properly for that certain period and after that powercycle it.
Posted on Mar 16, 2010
Anonymous
  • 10 Answers
SOURCE: WRT160N Wireless Router : linksys router wrtn160. where is the pin number...
You can find the pin number listed on the label on the bottom of the router.
Posted on May 20, 2010
Cisco WRT160N, all 4 ethernet lights on, so as the internet light ( no blinking ) ... power light and wireless light are totaly off. No connection at all. Tried reset, but nothing changed. The temperature...
Does holding the reset button in do anything? If not, might be that the router is simply fried and time to get a new one. If it does react to resetting try just connecting one device to it to see if you can get to the web interface and configure.
Oct 25, 2013 | Cisco Linksys WRT160N ULTRA RANGEPLUS...
Does my WRT160N have a WPS button and if so, where is it?
The Linksys WRT160N has WPS (Wi-Fi Protected Setup). If you are using WPA-PSK encryption (recommended), then you can easily connect the C4780 to your wireless network using WPS:
1) On the Linksys router, press the WPS button that is top of the case just under the Cisco label. When the LED on the button starts to blink, then the WPS process has started.
Jul 06, 2011 | Linksys WRT160N Wireless Router
Power was turned off to the house. When power came back the router is blinking blue lights and can't see the modem. Disconnected the computer from the wireless and plugged directly into modem and it's...
just as a guess try unplugging power to both modem and router, then plug only modem in first until connection light stops blinking and goes solid. then plug in router.
Dec 23, 2010 | Linksys WRT160N Wireless Router
Why is my port lights and internet lights blinking no power light comes on at all?
If the indicator for the numbers and the internet are blinking like christmas lights, this indicates that might be a hardware problem on your linksys router. A working router should show solid green power light. You may still resolve this by upgrading the firmware of the router.
Jun 11, 2010 | Linksys WRT160N Wireless Router
Linksys WRT160n V2 Wireless-N broadband router was working not long ago then just.. currently all lights are blinking i dunno what wrong please help?
Mar 15, 2010 | Linksys WRT160N Wireless Router
Linksys wrt160n router. wireless xbox won't connect
I made it an unsecured connection and everything worked. Not ideal solution, but it worked.
Feb 07, 2010 | Linksys WRT160N Wireless Router
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Apr 09, 2009 | Linksys WRT160N Wireless Router
Linksys WRT160N Wireless Router  Logo
3,336 people viewed this question
Top Linksys Computers & Internet Experts
Mike
k24674
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
