Yahoo Messenger Logo
Anonymous Posted on Jun 30, 2010
About signing in in yahoo messenger
Hi,i m getting problem while i m signing in in messenger.its showing message like please re-enter id n password.when i am using that pass word in my yahoo mail it works n also it works in other id but only my id its showing this error.please give me a solution as i am using yahoo messenger daily. thanks
  • Anonymous Jun 30, 2010
    ok so anytime we can use this command wenever there is problem for less speed?
Anonymous
Level 3:
  • Master 1,555 Answers
  • Posted on Jun 30, 2010
Anonymous
Master
Level 3:
Answers
1555
Questions
0
Helped
438677
Points
4726
Yahoo messenger presently is undergoing few changes at the server end. In order to login efficiently I use to run two ping commands. To do so, press on start button click on run button type cmd in the box and hit ok button. In the black window now type exactly the same in the bracket remember brackets are not included in the command (ping www.yahoo.com -t) don't forget to put space after .com before typing -t. -t is hyphen t. repeat this message once more and you will be able to login through messenger. Happy chatting
Testimonial: "hey thanks alot...!!!"
  • 2 more comments
    i have used that command but it continuously going on so i have to stop command window and then try to sign in in messenger?
    hey thanks alot....
    it works now....
    Sorry, I forgot to mention that after the command starts you have to minimize it and login to your messenger. If you are in a chat room. This will increase your speed so that your webcam will be faster and even the voice will be clear. If you wish to further know anything about any of the Chat related or any other technical issues you are most welcome to use fixya. Happy chatting
  • Anonymous Jul 02, 2010
    This is a tiny trick which I rarely tell people. In the organisation where I work thats totally on DSL modem and cat 5 copper cables even they use utp cables when going for more than 150 meters. Local sites open up very easily as the coppers are good but WAN sites from bangalore or delhi would take hours to open. I suffered for around one month then I got this trick. Simply ping the IP of the site to which you wan't to work faster way for you. -t in ping stands for ping continuously non stop till manually stopped. In case you don't know the IP you can simply put the web address like ping www.fixya.com -t and you will see the difference in speed on the links of that site. So enjoy and thanks for rating.
1helpful
Sign in problem(81003002) i getting this error from last 5days when ever i am try to log into my yahoo messenger even though i typed in the correct yahoo id and password. i ever tried uninstall and...
Clickthe "Messenger" menu in Yahoo! Messenger and select "ConnectionPreferences." 2.Enable the "No network detection" option and then click the"OK" button at the bottom of the window. 3.Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the "OK" button. 4.Enter your Yahoo! ID and password and click the "Sign In" button. youmay have a registry problem download registry cleaner reginout to fix the issue b>
Nu merge
HI, Please Follow these steps to configure your connection:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct.
i hope this will be helpfull to you. PLEASE DONN'T FORGET TO VOTE ME. GOODLUCK.......................
Problem sign in
hi,
I HOPE THIS WILL BE HELPFULL TO YOU. PLEASE DON'T FORGET TO VOTE ME
Pls help me i cant sign in on my yahoo messenger and email accout
Check if your password and id are correctly enter. Please check and enter it again. But if it continues follow the steps to recover your password and id.
First of all, you go to yahoo mail.
Click i can't access my account.
Select forgot my password or my account has be compromised
Click Next.
Enter your I.D and code shown below.
Verify your I.D.
Reset your password.
A message will be sent to you via e-mail. So there is when you will get your password back
I cant login on my yahoo messenger hellp me please
It is simple to log in on yahoo messenger. What you is to.
Click on the yahoo messenger icon.
Enter your ID and Password.
Then click Sign in. It will open.
So check your ID and password. If it is correct and try again.
2helpful
How can i sign up for yahoo messenger
you can sing up in many ways!! first you need to download yahoo messenger and install it! you can get it from:
http://in.messenger.yahoo.com/download/
now you can use your yahoo id to sign in. if you do not have a yahoo id then go to:
https://na.edit.yahoo.com/registration?intl=us&origIntl=&done=http%3A%2F%2Fmessenger.yahoo.com&src=maxw&last=&partner=yahoo_default&domain=&yahooid=
here you need to fill the form and make an yahoo id.
then just open the installed yahoo messenger and enter the login details that is Yahoo-id and password and click sign in.
you will be in yahoo messenger. enjoy the chat.
reply and rate me!!
9helpful
3answers
How to sign in in yahoo messenger chat
double click icon of yahoo messenger you will see sign id and password type there click signin
5helpful
I need to creat my acount in yahoo messenger
Hi
Here is how you can create your yahoo messenger account.
1) Download and install the Yahoo! Messenger program.
2) Go to the Yahoo! Sign Up page.
3) Enter in the necessary personal information in the "Tell us about yourself" section. You must give Yahoo! your name, gender, birthday and location in this section.
4) Choose the identification name you would like to use on Yahoo! Messenger and type this name in the "Select an ID and password" section. In this section, you must type in the desired Yahoo! ID name and the password you will use to log into the account.
5) Fill out the security information listed in the "In case you forget your ID or password" section. Enter two different questions and answers that could be used to retrieve your Yahoo! Messenger account information if you forget the sign in name and/or password for the account. You also have the option of entering an alternate email address in this section although doing so is not necessary.
6) Type in the security code at the bottom of the page and agree to the Yahoo! terms and conditions. Then click "Create My Account." You will be asked to confirm the creation of the account on a new Web page. Click "Continue" on this page and your Yahoo! Messenger account will be activated. You will then be able to sign onto Yahoo! Messenger.
If you have some more questions, please let me know.
Otherwise, please leave positive rating and feedback.
I cannot connect to yahoo messenger, it says, there was a problem signing you in to Yahoo Messenger Please click "try again" to re-enter your ID and password, if you have forgotten your ID or password,...
May be ur entering wrong password or id.....click on forgotten password....if u remeber ur correct mail id enter ur mail id....or u can answer the two questions and enter your date of birth.....if u enter it correctly it will let u change ur password n u can agin login using new password......hope this helps....
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
