Apple iPod touch Logo
Question about Apple iPod touch
How do you delete a song on the ipod touch - Apple iPod touch
Posted by 99abby_grace on
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Open itunes up go to the folder that the song is located under then delete the song plug your ipod into the computer and itunes should automatically delete it off your ipod for you.
Posted on Jul 29, 2010
Joe Negus
    An expert that gotĀ 10 achievements.
    President:
    An expert whose answer gotĀ voted for 500 times.
  • 652 Answers
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Posted on Jun 30, 2010
5 Related Answers
Anonymous
SOURCE: can i put new songs onto my ipod without the other ones deleting?
EACH TIME YOU HOOK UP TH EIPOD IT REINSTALLS ALL THE EXISTING SONGS ALONG WITH NEW ONES. YOU CANNOT DELETE THEM AFTER YOU INSTALL THEM OR THEY WILL ALL BE DELETED THE NEXT TIME YOU HOOK IT UP.
Posted on Jul 27, 2007
Anonymous
  • 31 Answers
SOURCE: Ipod touch keeps repeating songs on all playlists
when you are playing a track holding the iPod Upright on the Left hand side under the Track Time there is a Symbol with two arrows in a circle. If this is Blue you are on Repeat All, Blue with a 1 is repeat Track. You want it to be White. On the Right is Shuffle. Good Luck!
Posted on Apr 29, 2009
Anonymous
  • 68 Answers
SOURCE: Songs I've put on Ipod aren't there.
You need to sync it
Posted on May 09, 2009
jamielwright
JAMIE L.WRIGHT
  • 75 Answers
SOURCE: all my songs deleted from my ipod
Try the link.It may help.
http://www.recovermyipod.com/
Posted on May 31, 2009
Anonymous
  • 30 Answers
SOURCE: deleting songs
connect it to itunes.. click on the ipod and under the music tab.. uncheck sync all music from music library
Posted on Mar 30, 2010
How do i delete all songs on ipod shuffle and then reload? I want to empty it and start over as if new
Generally speaking, people will clean up their iPod with iTunes to erase the old songs and add new songs. iPod users have two ways to delete music from iPod with iTunes, and they can be helpful when iPod users want to get rid of the unwanted songs. iTunes provides automatic and manual methods to help iPod users manage the songs in their devices. When you are using the automatic way to manage iPod music, every time you connect iPod to computer with USB cable, your iPod will sync with iTunes Music library. If you have your iTunes Music library organized, you can delete unwanted music from iPod with this easy method. If you want to manually edit your iPod music, you can check Prevent iPods, iPhones and iPads from syncing automatically in iTunes by clicking Edit > Preferences > Devices. Then you can manually sync the songs and playlists to your iPod with iTunes.
http://www.leawo.org/tutorial/how-to-delete-music-from-ipod.html
tip
How to delete each and every song from your iPod touch
<p>If your iPod touch is filled with songs you do not want to hear it or not, eliminating each number is the quickest and easiest way to get a clean slate, so you can synchronize the device with just the songs you want. Although you do not immediately delete all your music from the device will connect your iPod to your computer and use iTunes to delete each number to delete all songs on your device without the songs in iTunes. <br /> <p><br /> <p>1. Connect your iPod touch to your computer and open iTunes if it does not open automatically. <br /> <p><br /> <p>2. Click on your iPod touch in the iTunes window under "Devices." <br /> <p><br /> <p>3. Click "Summary" and click the box next to "Manually manage music and videos" to check one place. <br /> <p><br /> <p>4. Click "Apply." <br /> <p><br /> <p>5. Click the arrow next to the iPod touch to the left of the iTunes window. <br /> <p><br /> <p>6. Click on "Music" and a list of all the songs on your iPod touch to open in the right pane of the iTunes window. <br /> <p><br /> <p>7. Hold down the "Shift" key on your keyboard and click on the top of the list in iTunes and click the last song in order to select them all. <br /> <p><br /> <p>8. Press the "Delete" key on your keyboard to delete all songs on your iPod touch. <br />
on Jul 21, 2011 • Computers & Internet
2answers
Delete songs from i pod touch 2nd generation
You must connect to the computer with iTunes. There you can select the music you want t delete.
For that wait till the iPod is backed up by iTunes, then on the left side click on the line with the name of your iPod. Then on top click on Music and then you see what music you can synchronise.
If you already did remove the original backups from the music on the iPad, there is a chance iTunes all remove all these numbers.
Apple has lots of info about every part you want to know about your iPod and iTunes.
3helpful
5answers
How do i delete songs of my i pod
The first way is uncheck the songs you want to delete on iTunes and then sync iTunes with ipod again, then the songs you want to delete will lose from iPod.
The second way is use leawo iTransfer to delete songs from iPod, the way is connect iPod to leawo iTransfer, then right click on the music you want to delete from iPod on leawo iTransfer to choose "Delete", then the music will be deleted soon. However, this tool can only work on Windows computer.
How do i delete songs off the ipod touch?
Sync your ipod to your computer and itunes will read all the saved songs on it and under library of itunes just select the songs you do not want to have in your ipod and delete.
hope it helps you.. please rate.
3answers
HOW TO DELETE SONGS
Go On iTunes Library And Click On The Grey Checkmarked Box If You Dont Want The Song. Then Resync The iPod
2helpful
2answers
How do you delete songs from Ipod?
To delete music connect ipod to itunes on computer.In music folder under your ipod name you can then delete music.
3answers
Deleting songs , how do you delete songs off the ipod touch?
3answers
How do I erase a song on an iTouch?
you can only erase or save tracks in itouch through itunes
Dont forget to rate
3answers
Waht to delete some songs from ipod
delete them within I tunes programme
Top Apple Audio Players & Recorders Experts
woodzowl307
Marvin
Marvin
W.L.
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
