Check the disc for any scratch,try cleaning it using a soft cloth,if still the same issue,try other game disc ,check if it will happen with other game disc,if not, the modern warfare disc is the issue,but if the error persist with all the game disc,the problem is your console you need to call xbox your repair
Make sure the disk is smoudge free if thats not the problem then in the saved game data you probably have a corrupt file somewhere or in the games data file. You will have to delete both of them.
once you put the cd in your computer all you will have to do is click on computer or my computer. ytou will then see the cd in the cd drive. it will probably say call of duty or something to that effect. then all you will have to do it click on to open and you should see something that says setup.exe or something close to the that ends in .exe and you will click on that and it will install automatically for you.
It would seem, from what you have told me, that your profile has been banned from Modern Warfare 2 for some reason. Try another profile and if that doesn't work, repost with any other information you can give. Thanks.
if other games run ok then
1. if your xbox says OPEN TRAY then its mw2 disk problem may b scratch on disk.clean the disk
2. if you have a moded xbox and other games run and mw2 is not and your xbox says PLAY DVD you need to update your flashing to wave 4
The new games have a new format which makes it simplier and it could be as easily wrong as some dust on the lens on the disc reader to hardware failure try your friends HDD and if it works with all games it is your HDD
Quite possibly the laser is becoming weaker, which causes read issues. First thing to try is simply putting a cleaner disc in and running it a few times.
This is not an uncommon issue. I have the same problem. This happened with the release of Call of duty modern warfare2. Seems that something to do with this game has glitched the servers and caused the trophy sync not to work. No word as of yet from Sony as to when this will be fixed.
