To change the language settings on a Playstation 2 console, proceed as follows:
1. If there is a game disc in the console, remove it and then power the unit on/off.
2. When the opening screen appears, choose the bottom option of the two. You will see the foreign text, then the time and date beneath it.
NOTE: If you do not see the date, scroll through the options until the date appears.
3. Press UP once to get to the language select option.
4. Press X to select this option, and then select the choice to the right (English) by pressing X.
5. All the text should change to English.
6. Return to the Time and Date Setup and verify or set your time zone.
7. Press CIRCLE to exit the configuration menu.
8. Insert the game disc and navigate to the Browser menu to select the game or browse the memory card.
NOTE: If the PS2 is currently in another language, then you need to figure out which language it is in so that you can look up the translation for ENGLISH. Once you have that figured out, it should be a matter of changing it back and calling it a day.
Hi
Go to the control panel, click on the icon that looks like a globe; you have a drop down menu that will change to any language. On a Windows Acer laptop, the display language is the language used to display text in wizards, dialog boxes, menus, support topics, Help menus and other components and interfaces. By default, your Acer laptop comes with a variety of display languages you can choose from if you are interested in changing the language. Alternatively, you can also install display languages. Click the Windows "Start" menu, click the "Control Panel," click "Clock, Language, and Region," and then click "Regional and Language Options." Click the "Keyboards and Languages" tab, and then select the language you want to use under "Display Language." Click the "Install/Uninstall" button if you do not see the language you want to use. This launches the language installation wizard. Follow the guided prompts. If prompted, type your administrator password. Click "OK" to save the changes. Thank you for contacting fixya.com
Please get back to us if you have further query else please accept the suggestion.
