What does ER FF mean on my Kenmore Elite bottom freezer refrigerator
Hi
Thanks
for using FixYa. Error ff is freezer fan fault. This usually happens when
either the rear board has gone bad or the freezer fan itself is bad and needs
to be replaced. To check what is causing the error you can start with checking
the fan which is located behind the back wall inside the freezer. Also check
the rear board as it might not be putting the fridge into defrost long enough
and is causing the ice to build up in the freezer and thus stopping the freezer
fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs
which will melt all the ice then plug it back if still the issue is not
resolved and you hear the fan running then it is the rear board that needs to
be replaced. Please do rate the solution if the issue is resolved or else
revert for further assistance.
Thanks
Rylee
