Question about Miele 24 in. G870 Built-in Dishwasher
Dishwasher runs and never stops
Miele 870 dishwasher runs in the same cycle and never stops... dial never rotates
Posted by mikeodarr on
David
  • 177 Answers
Sounds like you would need a new timer which can be purchased from Miele directly or through a authorzised service agent
Posted on Jul 01, 2010
We have a Miele G 870 SC dishwasher. The soap dispenser always opens properly to dispense soap if we run the Economy cycle, but it always stays closed if we run a Normal or Intensive cycle.
I would certainly check with the repairman and have it checked. It is possible that a connection may have been missed since the new dispenser was installed.
Oct 02, 2017 | Miele Dishwashers
Miele 870 dishwasher..timer works but doesn't wash goes thru cycle but no evidence washing or water swishing around.
I had this happen when my "water pump" went out on my dishwasher. It wasn't pumping the water up and into the machine or pumping it out.
Jun 05, 2017 | Miele Dishwashers
CI am having a problem getting our Miele G575 dishwasher to run through a wash cycle. It definitely has power, the water is on and there is no water in the bottom of the dishwasher. When you turn the...
You said it does not progress...meaning the dial does not eventually move? it may be waiting on a water level sensor to be tripped. The dishwasher is just not filling. The water valve solenoid may be stuck or defective. or a wire may have come off the valve solenoid.
Mar 08, 2011 | Dishwashers
Drain pump runs non-stop. Continues when dial is in Stop position. When disconnected for hours, drain pump starts immediately when power restored. In any wash cycle position, drain pump runs and cycle...
sounds like the flood switch has activated.
You will have to drag the dishwasher out from under the counter after turning off the power to it. Tilt to one side so that any water collected under it is expelled. This will free up the flood switch. Wait about 30 minutes and turn the power back on.
There could be a leak of some sorts from the door seal or hoses which is causing the water to collect.
Hope this solves the problem. It is unclear why none of the lights are lighting up to show a fault condition.
Nov 09, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele dishwasher not working
your timer is shorted out. probably caused by a cockroch
Aug 06, 2008 | Miele 24 in. G665 Built-in Dishwasher
Dishwasher not stopping
If it keeps going around then it is probably the programer timer motor unit. You will need to call Miele.
Jul 09, 2007 | Miele 24 in. G693 Free-Standing Dishwasher
Miele 24 in. G870 Built-in Dishwasher Logo
418 people viewed this question
Top Miele Dishwashers Experts
mpservices
 vpsoccer
vpsoccer
Michael Thomas
Michael Thomas
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
