Toshiba HD-A30 HD-DVD Player Logo
Question about Toshiba HD-A30 HD-DVD Player
Sound putput is breaking up. can verily understand
Sound output is breaking up. can verily understand words or other sounds. picture ok.
Posted by jpope1649 on
  • Robeye Jun 29, 2010
    What cables are you using? HDMI or component (5 RCA cables)? If HDMI, try putting it into another input on the TV. If the same problem occurs, get a new cable. If it does not and it only happens on HDMI1, the contacts are damaged.
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
Try a differ.speaker
Posted on Jun 30, 2010
I say I have a picture on my tv, but no audio. No matter how I type it in the search box, it comes up saying have sound but no picture. I don't understand. How can I trouble shoot the audio.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
I have the panasonic sa pt460 which is not outputting sound so i bought one off ebay for spares it had a power error so when ot was on for about 1 min it would cut out so expected all components to be ok...
Have you checked its speakers yet. Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
If the picture is OK in all respect, there should be sound.
How to hook the 3490 to get 4 ohms
Hello
The output impedence of the amp is 8 Ohms. It can also be connected to a 4 Ohms speaker, but the reted output will be higher than specifed, and the sound quality will be reduced. You cant get an putput impedece to this amp by no means, as its' output is desigend to match 8 Ohms/channel. If you have only spekers with 4ohms impedence, connect two of the in serieal connection, so that, they together will reach a resultant impedence of 4Ohms. Similarly connect an other two spekers in series to the other channel too. OK.
I hooked up the boston speakers 4 plus wolfer and when I play music on You Tube, the rear speakers don't play. They work in the sound "test." They also work when I set the speakers...
the sound on utube is only stereophonic, hence you will get only stereo putput. If you play anything recorded as quadraphonic or above all your speakers will give sound output.
There is no volume
Hello
Your Astar TV has no sound and picture OK I understands and posts this solution. Check first its speakers. If speaker is out there will be no sound output from the TV. If speakers are Ok, the sound card is defective and need replacement. You can check speaker with the use of a multimeter. Set the multimter to Ohms range and check the resistance of the two terminals of the speaker. It should be between 4 to 8 Ohms. If not, speaker is faulty and should be replaced. As in the case of sound card, it is a skilled work, and cannot be done by the user. OK.
1helpful
No sound
Hello
You haven't mentioned about the picture at all. Assuming that, picture is ok I suggests. Ok
If the picture is Ok and there is no sound output from the speaker, your TV has either speaker problem or output Ic problem. To assure where is the fault, you just place your ear very near to the TVs speaker side, and switch on the TV. If you hear a "thumb" sound or a "HUM" sound, your TVs output ic has blown out. If you did not hear any sound at all, the speaker of your TV has gone.
If you have a little knowledge in electronics, you can do it by yoursef. This is a minor mistake. Opwen the back cover of your TV, locate and note the type and number of the audio output Ic, go for that and get it replaced; if the fault is related to Ic. You can do the speaker replacement also by this way. I have given this much advice, assuming that picture in your TV is Ok. Otherwise the fault may be different.
Their is no volume
Hello
There is no sound you means? If so what about the picture? If picture is ok and there is no sound either the speaker of your tv or audio output Ic inside your TVs circuit board is faulty.
To check it, place your ear very close to the speaker side of your tv and turn it on. if a "thumb" sound or a "hum" sound is heard from your TVs speaker, the output Ic is faulty. If there is no sound at all, speaker is faulty. If you have any home theater system; and your TV has audio out RCA sockets at the rear or front side of it, connect it to audio system, and swich on both and find if there is sound output or not. If yes you can assure your TVs sound filtering system is ok, and the fault is somewhere between speaker and audio output Ic. Ok.
I download music then I can listen the voices of the songs just the music I think is the equalizer then I open the system to see whether I could repair but it will not do anything. open menu from the...
Hi Richard. Ok i can understand your problem. I was facing same problem with my cell also. but you dont need to worry you just need to reset your mobile phone settings. If that doesn't work then simply master reset your phone. All the problems will be solved then. You can do that by going to hte settings of your mobile phone. I hope this will help you in solving your problem.
3helpful
5answers
Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
