Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are disaligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to. Please refer to your TV's manual on how to do convergence and how to overlap the crosses because every CRT projection TV is different.
Convergence output chips got bad in your tv and need to be replaced to fix the picture issue.
It is not run the convergence feature in menu cure. It is hardware failure.
Visit this site it tells u exactly wat u need http://www.tvrepairkits.com/xcart/home.php?cat=1510
