Question about Apple iPod touch
How long to charge a new ipod touch - Apple iPod touch
Posted by joeymags916 on
Anonymous
    New Friend:
  • 72 Answers
Just charge it until the battery indicator indicates that the battery is full. If you want to make sure you properly condition your new battery, charge it for 12-16 hours, even if full. But usually, charging until full is sufficient, and should not take more than 6 hours if new.
Posted on Jul 17, 2010
1 Related Answer
seaniepie
Sean Cole
  • 255 Answers
SOURCE: New iPod touch does not fully charge
To fully charge takes about 4hrs. The first 2hrs are a fast charge bringing it to about 80%. The following 2hrs are a trickle charge to bring it to as near to 100% as it can get. It is possible that the iPod hasn't yet calculated what 'Full Charge' is yet based on your devices installed battery. Give it a few days. If it still does this after a few charges and near complete discharges then do a reset. to do this, while it is on press and hold the Menu and Standby/Power buttons for about 10 seconds until the Apple symbol appears. This should get it to do a self test which will re-analyse the battery.
All the best
Sean
PiDigital
Posted on Dec 28, 2008
Our sound dock does not charge our ipod touch 2nd gen. Bose manual says it does charge. The sound dock is not series 2. Are they not compatible? Thanks, Mark
The original SoundDock will not charge the iPod touch 2nd gen, or the iPhone 3G, or the new nano either. This is because Apple changed the way their new iPod products charge. (via USB only now)
There is 1 solution- Call Bose tech support. They can replace the 30 pin metal connector for a new one that will charge this. If this is not under warranty, it will cost $99, but it's worth it. New 1 year warranty, and compatibility with all iPods (except much older- non-clickwheel iPods)
Jun 21, 2009 | Bose SoundDock digital music system...
Jamo i200 doesn't charge iPod Touch
have you tried changing the charger or charging it through a computer. some chargers are too outdated for the ipod to charge!
Jun 20, 2009 | Jamo I200 Ipod docking station
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
i have the same problem with the old docks not charging my ipod touch and yes new bose docks and ihomes charge the 32g ipod touch
May 15, 2009 | Bose SoundDock digital music system...
Ipod touch wont charge
After a while the ipod batteries go bad.
Have a technician install a new battery for you and your ipod will work fine.
I DO NOT recommend this as a do it yourself Job.Th ipod touch has a battery that is soldered in and is not easy to install. pay the money to have a tech do it and you will be happy you did.
I charge my customers around $35.00 (installed) for the battery so you should be able to find it for somewhere around 35.00 - 50.00
May 10, 2009 | Apple iPod touch
Will the jbl on stage micro charge the new ipod touch
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
Feb 27, 2009 | JBL On Stage Micro Portable Speaker Dock...
I200 not charging ipod touch
Hi yes the touch is too new for almost all docking stations as i have the same problem your best just charging it through the computer or the socket.
Jan 02, 2009 | Jamo I200 Ipod docking station
My Jensen ipod docking system wont charge my i touch
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen).
If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
Dec 26, 2008 | Audiovox JENSEN IPOD DIGITAL DOCKING...
Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
Oct 28, 2008 | Apple iPod touch
Ipod not getting connected to itunes nor getting charged, and please recommend which ipod converter to download. Thank you in advance my ipod is not charged, when connected to a computer
hello!
if your IPod touch is not connected to itunes, please try the ff:
Check the iPod touch Display
-- When you connect iPod touch to your computer, the iPod touch should display an image or message on the display
-- If you do not see any image, check some basic troubleshooting here: http://support.apple.com/kb/HT1737
-- If you see a message on the screen, this indicates that the iPod touch does not have sufficient battery charge to operate and will need to be charged for several minutes before it can be recognized in iTunes.
Verify Windows PC System Requirements
--iPod touch requires iTunes 7.4 or later
Check USB Connections
-- iPod touch requires USB 2.0 to function properly
-- Try connecting iPod touch to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPod touch to your keyboard's USB ports is not recommended.
Restart your PC
-- In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
Verify iPod touch Driver/Service Installation
-- iPod touch requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPod touch the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service.
May 08, 2008 | Apple iPod touch
Apple iPod touch Logo
193 people viewed this question
Top Apple Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
