ASUS A8V-VM Motherboard Logo
Bennie Boyce Posted on Jun 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
Rofel Lantican
Level 3:
  • Master 2,632 Answers
  • Posted on Jul 23, 2010
Rofel Lantican
Master
Level 3:
Answers
2632
Questions
Helped
597474
Points
7882
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
2answers
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
I have ASUS A8V-VM Motherboard a8v uayvz with amd 3700, what upgrades ave available ?
Hi Cheqel,
Here is the weblink which has all the updated version software for your motherboard.
http://usa.asus.com/Motherboards/AMD_Socket_939/A8VVM_SE/#download
This will be great.
I have ATHLON 64 3000 processor, 32 Bit Operating mode,socket 939, 1 GB DDR RAM,ASUS A8V-MX motherboard and Viewsonic 19 inch VA1912wb,monitor.I desire better graphical display on my monitor. System is...
You did not list the card specs (AMD/Nvidia model) for reference. If you don't have a card currently get the best AGP 8x card you can find. Keep in mind that that with that CPU a higher end card will probably bottleneck so don't go crazy. Some web consensus is a geforce 5500. Possibly a Radeon 7000 series for higher frames.
I have missed the motherboard Cd for my A8V-VM SE with AMD processors so which are the drivers are to be loaded so as to detect the sound card and VGA
Download the drivers you need from Asus;
http://www.asus.com/Search.aspx?SearchKey=A8V-VM%20SE
Realtek Audio Driver and VIA Onboard VGA Driver.
Once the site above loads you'll need to click on the drop down menu and click on you're operating system.
Thats it!
Good luck
Mike
1helpful
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
2answers
Asus motherboard a8v-vm jumper setting motherbord on but cpu fan not ON
You do not use a jumper to run the CPU fan. There will be a small 3 or 4 pin plug near the CPU mount and you can plug the wire from the fan into that plug only. If the one on the motherboard has 3 pins and your plug has 4, you can use it anyway; just be sure the slot on the back of the plug matches the side of the one on the board.
2helpful
DDR2 with ASUS A8V-MX motherboard
This motherboard supports AMD 939 pin Athlon 64 FX/ Athlon 64 processors with 1MB, 512 KB L2 cache which is based on 64 bit architecture. It features 1600 MT/s HyperTransport Bus, dual-channel unbuffered DDR400 memory support and AMD cooling Technology. So you should be able to use the RAM as long as it falls into the above specs. Hope this helps & please remember to rate my answer. Thanks.
Power Reaching the MB but NOT reaching the cpu fan
Either replace the line to the fan (or get a new fan with a longer cord )or leave the side door of your CPU off a bit and maybe put a fan beside it.
1helpful
2answers
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
