Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
Toshiba tz50v51 problem
When i turn it on it may power up fine,picture and all working great. seconds later it goes off and power button on front will flash.unplug it, turn it on ... it may work fine the rest of the night ,it may go right back off.each time i have to unplug it. picture is fine when it is on just seem to be an issue with something maybe getting hot??? again only problem is at start up.....ideas???
Posted by goutieboy on
Piotr Pachkaev
    Master:
  • Toshiba Master
  • 304 Answers
Hi!
Seems that it's not a well-known problem, but I'm adding a link to the "troubleshooting" part of the manual - hope it will help!
Posted on Aug 09, 2017
3 Related Answers
Anonymous
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
Anonymous
SOURCE: Flashing Red Power Light
i had to replace the power supply
Posted on Oct 26, 2007
Anonymous
  • 125 Answers
SOURCE: Toshiba TZ50V51
andrews electronic in santa clarita ca but they are very expensive your best option is to find a used one
Posted on Aug 21, 2008
Tv stopped working and red light started to blink
this problem can be solve by changing the 2 IC of convergence. part # STK 392-110. It would take 30 to 60 minutes to open change and reclose.
Apr 23, 2010 | Toshiba TZ50V51 50" Rear Projection...
I have a toshiba tz50v51 projection tv. the red power light is on
It could either be due to the convergence Circuits ( If the Power Indicator Blinks) or the power deflection board if it doesnt blink. I have a source for parts if you would like the link.
Jun 20, 2009 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TZ50V51 powering down...flashing led
Resolder all pins of Z801 on power suppy board.
If that didn't fix it post back.
Jun 17, 2009 | Toshiba TZ50V51 50" Rear Projection...
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
I'd like to add another on the power problem
A common failure in these units is Q401, Toshiba p/n# Bz510004 is a 2SA1624 (HV amplifier) which finally fails due to a resistor R408 Toshiba p/n# Bz210285 a .47 ohm/1w metal oxide having changed in value and at last opening...
This isn't an expensive repair for a qualified shop - but I would suggest not continuing to test your shutdown circuit. What's happening is that HV (high Voltage) is builds beyond tolerances and the shutdown circuit turns your unit off to keep from causing any severe damage. If it failed you could likely burn out the SMPS or cause some substantial damage..
Good Luck!
Bill
Nov 10, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
