Question about Masterbuilt 20070106 Electric Smoker
My smoker no longer heats up - Masterbuilt 20070106 Electric Smoker
Posted by crmaynor on
Anonymous
    New Friend:
  • 7 Answers
I just bought a new Masterbuilt Smoker by default, two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem.
Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
[email protected]
Posted on Jul 03, 2010
When reaches heat, it slows heating and does not start heat up again
Just guessing, but sounds like the thermostat is bad or the sensor inside the smoker is cracked a little and when it gets hot it expands enough to break connection to the control unit.
May 26, 2014 | Masterbuilt 20070106 Electric Smoker
If I'm smoking peppers why would I use the water tray in the smoker?
the water keeps the peppers moist with out the water thay would dry out the choking down or opening the door is up to you with the door open the faster they will tend to cook more air equals more flame wich equals more heat . door closed less heat more smokey flavor and takes longer to cook
Jul 21, 2012 | Grilling
Can I get replacement for the heating element model 200700106 serial GA040909
The element kit is Part # 9907079003. So first try Masterbuilt 1.800.489.1581, as they use this same element in a couple of different models. My primary source for grill & smoker parts, Appliance Factory Parts, says it's no longer available. So Masterbuilt may be your only source. But, to be very candid, that's iffy, at best. Masterbuilt is not known for having critical parts for their smokers.
I hope this wa of some help to you and thanks for choosing FixYa.
Jul 24, 2011 | Masterbuilt 20070106 Electric Smoker
While using my Masterbuilt smoker (Model 20070106) the temperature began to gradually decrease and now it will not heat at all. I'm sure the heating element needs to be replaced but I am having...
SgtDave - Don't feel like the Lone Ranger. There have been a bunch of people seeking either the burner element and/or the electronic controls. The burner element is available form Appliance Factory Parts, but only with the smoker box. At one time is was sold separately, but now, the element by itself is no longer available. Even Masterbuilt no longer sells just the heating element. In part, if you check your Owner's Manual or the Manufacturer's Data Plate on the smoker, take note of the Country of Origin, you'll understand why.
Wish I could have been of more help to you.
Jul 11, 2011 | Masterbuilt 20070106 Electric Smoker
Bought little chief model 20 smoker don't know how to use it...
The Little Chief smoker, manufactured by Smokehouse, is available in front-loading and top-loading styles. Both models are electric, depending on a 250 W electric heating element to supply the heat. The smokers can accommodate a maximum of 25 lb. of meat or fish. These smokers are for outdoor use only, and plug into a 120 V AC electrical outlet.
  1. Brining
    • For extra flavor, treat your meat, poultry or fish to a brine bath before smoking. Use 1 cup of kosher salt for each gallon of water. Consider adding molasses, spices or even a pureed jalapeno pepper or two into the brine solution. Leave thicker pieces of meat in the brine solution overnight. Fish only need to be soaked in brine for around four hours.
    Wood Chips
    • Mesquite and hickory are probably the two most widely used woods for smoking, but apple and pecan wood can give your smoked foods another tasty dimension. As with anything else, experiment to create your own favorites.
      Smoker wood is sold either as chips or chunks. Use large chunks to smoke thicker pieces of meat; the chips will be spent before they have thoroughly smoked the meat. You can continually replenish the chips, perhaps every half hour, for as long as you wish to smoke the food, but the job can be tedious with a large roast that takes hours to smoke.
      Smoke the wood well before it is introduced to the heat. Chips will be completely soaked in a half hour, but chunks of wood will require an overnight soaking before use.
    Smoking
    • When your meat is thoroughly brined, and the wood soaked, carefully lay out the meat on the smoking racks. Make sure that there is some space between each piece. Place fish on the rack with the skin-side down. Drain your wood and place it into the smoker on top of the heating element. Use the small pot that is provided to keep moisture or collect juices. Place the racks into the smoker and close up the box. Plug in the electrical cord and within about 10 minutes, you should see smoke gently trickling out from the smoker's vents. The thicker the food inside the smoker, the longer the process will take.
    Mar 18, 2011 | Luhr Jensen Little Chief 9800
    We have the masterbuilt 700 series digital smokehouse. The wood chips are no longer burning - we have no smoke. Is the repair easy and cheap?
    You probably have a bad heating element, Turn the unit on then turn your digital heat to 275 and open door the heating element should become cherry red. If it doesn't then you have a bad heating element. If you do not get a digital readout then you probably have a bad digital control panel. Both of those parts can be replaced, however i do not know the price for either of those parts. If you have neither working then you may have a short or broken wire that is not making a full curcuit. Good Luck
    Jul 28, 2010 | Masterbuilt ESQ30B Smoker
    Digital panel no longer works. need source for circuit board and approximate cost
    Masterbuilt Digital Smoker no longer heats up and digital display has stopped working completely. The unit acts like there is no power to it and is completely dead. By replacing the digital component will this solve my problem
    Jul 01, 2010 | Masterbuilt 20070106 Electric Smoker
    Was given a brinkmann gourmet charcoal smoker/no manuals
    Sure...the smoker top and middle lift off. There is a pan that goes over the charcoal pit. The pan is used to create moist heat. It will produce steam while you cook. I recommend flavoring whatever fluid you put in the pan with fruit, fruit juice, or frozen concentrate, or wine, mixed with water. You can put your initial batch of charcoal in the bottom, (pit) and fire it up just as you would any charcoal grill. once the coals are ready, you can put the pan over them, put the middle section in, (with whatever meat you prefer), then finally the top. During cooking, to produce a smoky flavor, you can put water soaked hickory or misquete chips with the charcoal, it has a door for access. You can also add charcoal as needed to maintain the desired heat level thru the door. Remember, it takes longer to prepare food on the smoker, the key is low heat and longer cooking times. For example, I usually cook a boston **** at about 185 degrees for up to 12 hours. Bon Appetite!
    Oct 05, 2009 | Brinkmann Gourmet Charcoal Smoker/Grill...
    Won't heat
    I have the same smoker with the same problem. I checked the heat element with an ohm meter, it was good so just cleaned the burnt residue from the male spade connectors attached to the element with a dremel tool. Slipped two new female spade connectors over the ones on the element and soldered them with the wires attached with a 1/16' silver bearing electronics solder. Now the connections cannot become loose and burn up again. I tested everything out and then wrapped the exposed connectores with non conductive fiberglass electrical tape and covered everything with expanding foam that comes in a spray can. Easy fix for me after reading all the posts from you guys here. Good luck and go for it! All I had to buy was the foam insulation.
    Gary
    Corpus Christi TX
    Jul 13, 2008 | Masterbuilt ESQ30B Smoker
    Heat shield for model FG22O4C
    This grill was discontinued over 6 years ago. There will come a point when spare parts are sold out.
    Jun 24, 2008 | Uniflame FG2204C Grill
    Masterbuilt 20070106 Electric Smoker Logo
    488 people viewed this question
    Top Masterbuilt Grilling Experts
    Paul Carew
    William Miller
    William Miller
    Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
