Question about Dell Inspiron 1318 Notebook
I have Dell inspiron 1318 the cd is stuck and I can't get it out please hlep me !!!
5 Related Answers
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Sound Card Driver for Dell Inspiron 1318 in Windows XP
Sorry for the typo, it was suppose to be Dell WEB site
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still type in the Service Tag number, it is printed on the label on the bottom of the laptop. Also make sure you select the Windows Vista version of the driver for your Windows operating system.
Click on this link :-
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Posted on Apr 08, 2009
Anonymous
SOURCE: Need Wifi driver for dell inspiron 1318 (XP)
Uninstall any wireless drivers for have incorrectly install in device manager. Reinstall the Chipset driver over whatever is installed and then reboot. Extract the 174291 driver into a folder and manually install the wireless and it should work
Posted on Apr 10, 2009
Anonymous
SOURCE: my microphone stopped working and its built in
I had thesame problem on a brand-new Dell laptop. The solution is to intall IDT STAC9228 Audio Driver (file R204473.exe), which can be downloaded from Dell web site (http://ftp.us.dell.com/audio/R204473.EXE). This solved my problem with not having mic when using Skype.
Posted on Aug 19, 2009
Anonymous
SOURCE: my dell inspiron 1318 right hinge is broke from
i have same problem with 1318 and just relized today that there were to small little screws missing on right side hinge. screen was very loose and would easily fall backwards . i managed to find sum in a junk draw and put them in as good as i could and its feels like new again. i plan on getting correct screws online or from hardware store but its good for now
Posted on Dec 21, 2009
Anonymous
  • 128 Answers
SOURCE: dell inspiron 1318 lcd screen completely dim
The backlight in your LCD has gone out. You will need to replace the entire LCD. You can look on ebay or here, you will be paying around $300 for it.
Good Luck!
Jesse
Posted on Jan 05, 2010
Is the dell inspiron 1318 model pp25l touch screen capable
the short answer is no, it was an economy laptop maybe 5 years ago so would not have been equipped with what would have been a very expensive option
Dell Inspiron 1318 review
http://www.expertreviews.co.uk/laptops/47718/dell-inspiron-1318-review
Nov 29, 2015 | Dell Inspiron Computers & Internet
We have a disk stuch in a dell inspiron 1318, there is no OS on it right now. how can we get disk out? there is no place to stick the paper clip
Remove the optical drive, and then open the drive. Remove the disk.
With most laptops this is a simple job.
Turn the laptop over on it's top, remove one Philips head screw, pull the optical drive out.
Remove 2 to 4 screws from a cover on the optical drive, and ease the tray open.
With the Inspiron 1318 Notebook PC it is more difficult.
A) Remove the Display Assembly.
(Removal covers removing the Display Assembly as a whole unit, off of the laptop)
B) Remove the Keyboard.
C) Remove the Palm Rest. (Top cover under the Keyboard. Your palms rest on it when you use the touchpad)
D) Remove the Optical Drive
Dell Support > Dell Inspiron 1318 Service Manual,
http://support.dell.com/support/edocs/systems/ins1318/en/sm/index.htm
In the list click on Optical Drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 16, 2011 | Dell Inspiron 1318 Notebook
Sometime read cd or dvd, sometime not read cd dvd. i have dell inspiron 1318 laptop pls help me.
The problem may be for a variety of reasons,
can you please let us know the DVD drive maker name.
You can find it under, My Computer-> Right click 'Properties' and choose Device Manager.
Also you can try to update your firmware for the DVD drive you are having.
Thanks.
Jun 18, 2011 | Dell Inspiron 1318 Notebook
Hi , I am unable to log in into my laptop as its asking for product key. I checked on the bottom of it and found that the product key is worn out.Please hekp me how can i get product key for it? Type...
Can you get ANY numbers off the sticker? What you can do is contact DELL and give them your service tag number, they should have your product key (on the bottom as well). Also, the number should be in the CD sleeve that came with the laptop.
May 16, 2011 | Dell Inspiron 1318 Laptop Computer PC...
Eject stuck disk in Dell inspiron 1318 notebook
Take a Norwegian paper-clip, and straighten one end.
Gently push that end into the small hole in the face-plate of the optical drive.
When you feel resistance, firmly push another 5 mm (1/5 inch).
This should "unlock" the tray.
Press the open/close button, and the tray should fully open.
Feb 19, 2011 | Dell Inspiron 1318 Notebook
My dell inspiron 1318 has the screen flicker and go blank within 30-60 seconds after starting up. I know the computer is running fine, but I just can't see anything. I am guessing this is a driver or...
have you gone to the dell on line support
try to reinstall the application, media , found on the icon or your cd recovery set --
there should be an icon on the bottom right of your screen - see if you can reach tech support -- you will need to give them your service tag # located on back of your laptop
i hope this helps, please leave me positive feedback
Oct 17, 2010 | Dell Inspiron 1318 Notebook
How to eject a stuck disk in the driver !!from inspiron 1318
There is almost always a tiny little hole on the side of Drives, Take a Paper-clip, bend it out straight and push it into that hole, this will disengage the lock on the drive holding the disc in, allowing you to open the drive.
May 17, 2010 | Dell Inspiron 1318 Notebook
I want to know what type of blank dvd?
You can use any kind of writable DVD the difference is that DVD-R, are more secure and data is better protected so you have a Combo or DVD+RW Drive 8X CD/DVD Burner (Dual Layer DVD+/-R Drive) that allows you to use a double layer DVD+ R or CD + R
if it works for you don't forget to rate me
thx
May 16, 2010 | Dell Inspiron 1318 Notebook
Dell inspiron 1318 lcd screen completely dim
Good Luck!
Jesse
Jan 05, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Drivers for dell inspiron 1318 xp operating system
i finally succeeded installing windows xp in my dell inspiron 1318 after 3 weeks of trial and error in installing different drivers.. wheewwwww. hope this will help you. just search for the following filenames in google and please download it but if you know any free sites where i can upload the following files let me know, so i can upload it there for you to download..
Dell_multi-device_A17_R174291.exe (for WiFi)
R153908.exe (for Audio)
Intel® Graphics Media Accelerator Driver for XP v14.33.1.exe
(for Video)
Intel INF Update utility v8.3.1.1009
(for Chipset)
r173082.exe (for Webcam - but it is included in the drivers cd provided by dell)
R161772.exe (for cardreader - but it is included in the drivers cd provided by dell)
Sep 06, 2008 | Microsoft Windows XP Professional for PC
Dell Inspiron 1318 Notebook Logo
415 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
