Question about Honda 2500 PSI Gas Pressure Washer
Pressure washer worked fine and suddenly no
Honda 2400 pressure washer worked fine and suddenly no pressure. Getting water thru it, but no pressure. Engine runs fine.
Posted by Max Fecko on
Anonymous
    New Friend:
  • 13 Answers
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
Posted on Jul 16, 2010
Honda pressure washer 2400 psi worked fine yesterday, today the pressure is low, seems to work fine except the level of press sure is low any suggestions?
Check for an inline filter on the water hose connection, the low pressure side. Depending on your water quality and if any spiders made homes inside your hose, they can get clogged pretty easily.
Jun 07, 2011 | Garden
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
Husky ran great for couple of hours. Now no pressure at all. Water comes thru for suds, but no near enough. Engine runs fine but will not build pressure. Checked for trash blockage-all clear. Thanks,...
Same old problem... water admitance valve sticking.
Remove the valve spool and clean the bore with crocus cloth on a dowel rod.
Replace O rings and lube lightly with plumber's grease. Reassemble... good as new!
The valve senses pressure and blocks further input water. It sticks in the high pressure position blocking water flow.
Aug 05, 2010 | Honda Pressure Washer PSI 3000
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
I have a Honda 2000 pwr. No pressure
check the o-ring in the pressure relief valve.
Sep 10, 2009 | Karcher 2500 PSI Pressure Washer
Husky 2400 psi honda engine ran fine all day
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Jun 27, 2009 | Honda Garden
Honda 2500 PSI Gas Pressure Washer Logo
804 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
