Question about Relic 0504648FA
Im applying pressure in the right direction but the pin wont budge
Michael C. De Vito
    Genius:
  • 1,970 Answers
Mcdevito75 here, I'm thinking you mean the stem (winder) Make sure stem is all the way in (flat on the watch) now turn the stem a little both ways, it could be locked down, if the stem turns and doesn't seem to be locked down, simply put a fingernail just under the crown and lift to set the time. If you mean the pin or spring bar to change the band, you"ll need a special tool to remove these pins or spring bars, the tool is available on ebay called a spring bar removal tool, or you can visit a small watch repiar shop in your area.
Posted on Jun 29, 2010
Broken Armani sign
Yes it can be fixed but may need a jeweller. You cannot take the glass face out on it own, you have to remove the watch back plate and then pull out the watch mechanism. (Once the back plate is off removing the mechanism is not difficult) You then have access to both the inside glass face and the watch face. If you can do this you will need to glue the Armani logo with something like super glue, but not applied directly to watch, too risky. If you have tweezers hold the Armani logo in them. Use a pin and dip it into a small blob of super glue, apply the pin to the back of the logo and then place it on the watch face as quickly as possible and align. Once aligned apply a little pressure with the tweezers on the logo to help adhere, about 5 seconds, leave to dry and then put watch back together. If this all seems to difficult a jeweller can do it in about ten minutes.
Jan 08, 2014 | Watches
After replacing battery can't get the backplate of AR0156 back.
If you cannot snap the back on with your fingers the only safe way to get the back on again is to use a watch press. This is an expensive tool that most jewelers will have. I strongly recommend you take it to a jeweler (may want to call first to make sure their company will do it because most chain stores will not work on most brands). They should not charge you.
If you are determined to do it yourself then you can try wrapping a wide pliers with duct tape or cloth and applying pressure on the front and back of watch to pop it on. WARNING: this is very dangerous for your watch. DO NOT apply pressure to the crystal, try to put the pressure on the stell lugs instead...
Oct 31, 2012 | Giorgio Armani Watches
The bracelet of my new Casio watch MTP3050D-2AV has some sort of flat fasteners. I inserted a tiny flat screwdriver in the hole at the arrow on the back, applied some outward pressure, but it wouldn't...
My son and I battled the same kind of watchband. WD-40 helped a lot. Also some links are much easier than others to remove, so if you are having trouble with one, try another. Seeing what it looks like will help you understand what you are up against. The thing you are trying to remove is L-shaped, with the foot on the side of the link and the long part serving as the pin joining the link to the next. The resistance the pin has to being pulled out is caused by a tiny bump on the foot; that bump has to be forced underneath the metal and out the other side, which you do by prying as you are describing. Make sure the links are lying flat as you do this; if the band is curved such that the two links are pulling on the pin, you'll never get it out. I'm not sure that a screwdriver is what you want to use for prying; a thin rod, like you get in a set of watch tools, is better. Hope that helps!
Dec 03, 2010 | Casio MTP3050D Watch
How can I remove link pins to adjust metal band from Raymond Weil ladies Tango 527462? One side of the pin has a slot head but a very small screw driver fails to turn the head. The other side has a flat...
Raymond Weil watch braclet has a screw. Twist it, and then push from the other side. You may need to buy a set of basic tool for about 10 dollars from Amazon. Good luck and enjoy your watch. Alan Anderson
Nov 09, 2010 | Raymond Weil 5360-STP-00328 Wrist Watch
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    Resize the watch
    If the band is screws then a small screw driver will do the trick. Make sure you use the right size screw driver so you do not strip the screws.
    If the band is put together with cotter pins you can push out the cotter pins with a small awl or punch. You want to apply pressure to the end of the pin that is not split or appears to be smooth. Usually when you have cotter pins they are arrows or indicators on the band to tell you which way the pins come out. Make sure you put the pins back the same way they came out.
    Sep 17, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
    Remove a link from an armitron ladies watchband model 6P29
    More than 90% of Fossil's watches utilize pins that push out.  You can determine whether or not it pushes out by checking if there is an arrow on the back of the link.  If there is an arrow, you should push the link out in the direction of the arrow.  Usually, the link needs to be pushed at least 25% of the way out before it will be loose enough to pull out.  I suggest using pliers and be sure you pull straight out or you risk damaging the pin.  Be sure to watch for a small tube or 'sleeve' that may be in the link.
    Jan 20, 2009 | Fossil CH2331 Wrist Watch
    Removing links on wave ceptor 106hdu
    I've just bought a WVQ-620. Punching the pin out in the direction of the arrow was straightforward. Quick tap with a hammer (strap positioned over a drilled hole on a piece of wood) and then pull out with pliers.
    I then discovered there was a small collet in the inner part of the bracelet (arrow end). Basically this is what holds the pin in place. And during extraction of the pin it can come out - it's very small, so be careful not to lose it.
    Any case, re-assembly was by putting the pin in (at the arrow end) giving it a sharp tap with a hammer so it locates in the collet and then just driving it right through so it is positioned just so.
    No special tools, just patience and good humour.
    Jul 30, 2008 | Casio Waveceptor Watch WVA106HDA2BV Blue...
    Link removal
    here are the steps SEARCH Watches Jewellery WATCHES JEWELLERY GIFT CENTER FEATURED ITEMS WATCH SPECIALS GIFT CERTIFICATES WHAT'S NEW HOME EN FRANCAIS ORDER TRACKING CURRENCY CONVERTER ABOUT US CONTACT US HELP How to Remove Watch Links The following method outlines how to remove most watch links. If you have any questions, please send us an email at [email protected] 1. Pin Type I 2. Leaf Spring Coupled Type 3.Single Screw Link Type 4.Snap Type 5.Bracelet Sizing Instructions 1. Pin Type I (Tools: Eyeleteer, Staking stand, Hammer or Pliers) Step 1. Set the watchband onto a staking stand or other appropriate holder. Step 2. Use an eyeleteer to push out the watchband connecting pin toward the arrow. If the pin is too tight, use a hammer to lightly tap out the pin. Step 3. Pull out the connecting pin with a pair of pliers. Step 4. The selected link can be disconnected from the adjoining link. 2. Leaf Spring Coupled Type (Tools: Tweezers or Pliers) Step 1. Use a pair of tweezers to push out the leaf spring of the link in the direction of the arrow. Step 2. Remove the leaf spring by using a pair of pliers. Step 3. Other types of leaf springs as illustrated above are also used in leaf Spring Coupled Type Watchbands. Step 4. Disconnect the link from its adjoining link. 3.Single Screw Link Type (Tools: 1-mm Screwdriver or Tweezers) Disassembly Step 1. Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side. Assembly Step 1. Reassembly is opposite of disassembly. Assemble the link, and turn the bracelet on its side. Insert the screw into the link either with a pair of tweezers or your fingers. The screw will only go into one side of the link. Step 2. With the bracelet still on its side, securely hold the bracelet between your fingers, and place the 1-mm screwdriver tip into the screw slot on the end of the screw. While using gentle downward pressure on the screwdriver, turn the screw in a clockwise direction until you feel the screw stop and the top of the screw is just below the edge of the edge of the bracelet. Do not apply more than gentle pressure on the screwdriver as it could cause the screwdriver tip to slip off the screw end, which may scratch the side of the bracelet. Step 3. Once the screw is screwed down in the link as fare as it will go, give the screwdriver one final"twist" to securely tighten the screw. Be careful not to use too much force as the screw head could become damaged. 4.Snap Type (Citizen Sizing Tool) Step 1. Remove the link pine in the direction of the arrow. Step 2. Grasp the band on either side of the link from which the pin was removed. Apply gentle upward pressure on the side nearest the case, while applying gentle downward pressure on the clasp side of the band. You will feel mechanism disengage. Step 3. While continuing to apply gentle pressure as outlined in the previous step, gently"rock" the band to completely release the mechainism. Step 4. After releasing the mechanism move the clasp side of the bracelet towards the case to dissemble the links. Step 5. Gently pull the links apart. Repeat the procedure for as many links as need removing. Reassembly is opposite of disassembly. 5.Bracelet Sizing Instructions (Tools: Citizen Blue Pin Pusher Link Joint Remover II or Tweezers) Link Components 1) Split Pipe -Two pieces, one at each end of the pin. Generally one split pipe will remain attached to pin during sizing. 2) Cylinder Link - Two pieces, one at each side of the bracelet link. 3) Link Pin - Connects link, cylinders and split pipes together. Step 1. Note the engraved arrow on the backside of the bracelet showing the direction in which the link pin should be pushed and lay the bracelet in the cradle as shown above. Align the pin of the pin pusher with the link pin, being careful to centre it. Once centreed?, apply slight pressure until you feel the pin begin to move and then turn fixture upright as shown in illustration . This slight pressure will keep the pin pusher in alignment with the link pin while the tool is being turned upright. Step 2. With the fixture standing in the upright position, apply even pressure to the pin pusher until the pin drops out. Step 3. Using the tweezers, set the pin/split pipe assembly and cylinder aside. If the cylinder comes off of the pin, reassemble the cylinder and pin. The split pipe for the link pin at this outside end is still on the pin and dose not need to be removed. To reassemble pin and cylinder, insert pin into the hole of the cylinder so that the split pipe rests in the recess of the cylinder. Set aside for use during reassembly of the bracelet. HOME TESTIMONIALS LEGAL NOTICE ORDER TRACKING F. A.Q'S REQUEST A WATCH ABOUT US CONTACT US En Fran?ais | Advertising Opportunities | Affiliate Program | Watches | Jewellery | Diamonds | Feedback | What's New Watch Search | Jewellery Search | Volume Pricing | Request a Watch | Specials | Privacy and Security | Site Map WebJeweller.com, Email: [email protected] Copyright © 1999-2006 webjeweller.com. All rights reserved.
    Aug 10, 2007 | Fossil AM3425 Wrist Watch
    Relic 0504648FA Logo
    284 people viewed this question
    Top Relic Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    robert
    ray gallant
    Are you a Relic Watch Expert? Answer questions, earn points and help others
