try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
Unfortunately this is not a user repairable problem. Either you LCD screen is failing or the ribbon cable connection is not good. Both are not repairable by the consumer.
The focus mechanism for this camera is different from other Fuji cameras in that instead of using 3 evenly spaced guide pins like on smaller compacts or, a motor and drive thread like the S5600 or S5700. The S1000fd uses a guide rod and spring and 1 guide pin to move the focus lens up and down to sharpen the picture. 1 pin is all that can jam and cause problems. Getting to it involves desoldering the control board from the main board just to access the lens unit. Then desolder 2 ribbon strips and secure 2 tension springs before you can remove the lens construction.
If the camera is beyond economical repair due to moisture, it usually means the insides have been corroded beyond measure. This means that corrosion would be all over the main boards in the camera, in the lens and also in the ribbon cables. It would cost less to buy a replacement off of ebay. Sorry for the bad news.
