Question about Kyocera FS-1118MFP Laser Printer
Reset the fuser code 6400 by pressing counter/system button, then go to service setting, then hold the start and hash button at the same time, now press enter and leave all buttons, press 163 and enter/execute, switch off and on, fuser will be reset, if not reset then replace fuser/fixing unit
Posted on May 05, 2014
Zero cross error. Could be the power source PWB or the control PWB bad.
Posted on Aug 26, 2010
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
Posted on Jun 12, 2009
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
May 17, 2014 | Kyocera FS-C5030N Led Printer
Mar 16, 2014 | Kyocera FS-1118 Printer
Oct 17, 2011 | Kyocera FS-1016 Printer
Jul 21, 2011 | Kyocera FS-1118MFP Laser Printer
Oct 26, 2010 | Kyocera Copystar CS-1820 Black and White...
Jun 21, 2010 | Kyocera FS-1118 Printer
Jul 14, 2009 | Kyocera FS-1118MFP Laser Printer
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
Sep 29, 2008 | Office Equipment & Supplies
918 people viewed this question
