NexxTech DP3222 DVD Player Logo
Question about NexxTech DP3222 DVD Player
Where can I find the remote for this device?
Posted by yvo0665 on
Anonymous
    President:
  • 1,285 Answers
Here you are
  • http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=NexxTech+DP3222+&uuid=12777825676710
feel free to rate the help
Posted on Jun 29, 2010
1helpful
The RCA remote seem to be able t do the job. How ever i am having problem doing the sequence 1. Code search, tv, power switch until it turns off. When it goes off I seem t be confused
They make a number of remotes, refer to manual.
Remotes - RCA
www.rcaaudiovideo.com > remotes
RCRBB04GBE. 4-Device Universal Remote-Streaming Player & Sound Bar Compatible. MSRP: $12.99 In Stock. RCRBB05BHE - 5 Device - Universal Remote ... ‎Remotes Support · ‎RCR503BE · ‎RCR414BHE · ‎RCR313BE
RCA Remote control support - how to program
www.rca.com > us_en > remote-control-support-904-us...
Your remote control support for RCA remotes. Find your remote revision number and get your remote code. See how to program your remote with our videos.
RCA 3-Device Universal Remote - Grey
www.thesource.ca > tvs-home-theatre > remote-controls
This sleek 3-device universal remote from RCA works with the latest home theatre products and brands in the industry, including new streaming devices.
I have orca universal remote I need help programming a Jayne dvd
    Hi Reginald, This is a bit long winded, but here we go!
    Manually Entering a Code
    Locate the code for your device in the RCA Remote Code Finder. Entering a device code is the fastest way to program your RCA universal remote. The code for your device will vary depending on your model of RCA remote.
    In the RCA Remote Code Finder, select the model number of your remote control from the "Model" drop-down. You can find your model number printed on the bottom of your remote.
    Choose the type of device you want to program under "Product Type."
    Find the brand of your device (e.g., Sharp, Sony) in the search results.
    The numerical code next to the brand name is the code you'll need to enter.
    Press the power button on the device you want to control to switch it on.
    Point your remote at the device. You'll need to keep the remote pointed at the device the entire time you are programming it.
    Your remote should have several buttons labelled with different device types, for example, the "TV" button would control your television, while the "CBL" or "SAT" button would control your cable or satellite box.
    The "AUX" button is usually assigned to stereo devices.
    Press and hold the device button that matches the type of device you are controlling.The Power light on the remote will light up. Don't let go of the button!
    Enter the device code while still holding the device button. This is the code you found in the Remote Control Code Finder. Make sure to keep pressing the button, even after the Power light turns off.
    Test the remote.
    I
    f the code was entered correctly, you will be able to turn the device on and off using the remote. Make sure you press the correct device button at the top of the remote before testing the features.
    Look at the Power light after entering the code. Make sure that you're still holding the device button. If the Power light has turned back on, the remote has been successfully programmed.
    If the light blinked four times and then turned off, the code may have been entered incorrectly.
    Try holding down the device button and re-entering the code
    If you are unable to turn on your device after entering the code, you may have the wrong code.
    Return to the RCA Remote Control Code Finder and make sure you entered the correct information.
    If you still can't program the code with this method, try using the Code Search button (if there is one) or doing a Manual Code Search.
    For a Remote Without a Code Search Button.
    Turn on the device you want to control.
    If you're unable to do an automatic code search and cannot enter the device code manually, try a Manual Code Search. Start by powering on the device that you want to control (e.g., your DVD player, stereo receiver).
    You'll only be able to use your RCA remote with devices that support remote control in the first place. If the device did not come with a remote, you likely won't be able to use your RCA remote to control it.
    Point the remote at the device. Keep the remote pointed at the device during the code search process.Press and release the device button that matches the device you want to control. For example, to program the remote for a DVD player, press the DVD button.
    The Power light will turn on.Press and hold the Power button on your device and your remote.
    Continue to hold until the light turns off and then on again. Press the Play or Slow button on your remote.
    Now your remote will try different codes in an attempt to turn off the device.
    Once the proper code is found (typically after about five seconds), the device will turn off.
    Press the Play or Slow button again. Do this only if the device did not turn off after five seconds. Pressing Play or Slow again will tell the remote to try the next batch of codes. Repeat this every five seconds until the device turns off.
    Press the Reverse or Skip Back button once the device turns off. This should turn it back on again. You may have to press this multiple times to find the correct code.
    Press Stop or OK to lock in your code.
    Once the device turns back on after pressing the Reverse button, you've found the correct code.
    Press Stop to lock it into your remote.
    For a Remote With a Code Search Button
    Note: Universal remotes can be finicky, and you may need to start the process over if something goes wrong. Make sure you are keeping the remote pointed at the device, and that you follow each step exactly.
    If there's a button on your RCA remote that says "Code Search" or "Set Up," you can use this method to locate and program device codes. Start by turning on the device you want to control.
    Universal remotes only work with devices that support remote control in the first place.
    If the device didn't originally come with a remote, you won't be able to use a universal remote with it.
    Point the remote at the device you want to control. You'll need to keep the remote pointed at the device as you program. Press and hold the Code Search button until the light turns on. This button is usually at the top of the remote. When the light comes on, you can let go of the button.
    If your remote has a "Set Up" button instead, complete this method using that button.
    Press and release the device button that corresponds with what you want to control. For example, to control a DVD player, press the DVD-VCR button. The light will blink and then remain lit.Press and release the Power button on the remote until the device turns off. Each time you press and release the Power button, the remote will try a different code for the device. Once the correct code is found, the device will receive the signal and turn off.
    This could take a while if the code for your device is at the end of the remote's internal list. There are a couple hundred codes that you may need to go through.
    If you go through the whole list without finding a matching code, the light on the remote will blink four times and then shut off. There's a good chance that the remote will not work with your device, since you've tried every code available.
    Press Enter on the remote when the device turns off. This locks the code into your remote. If you accidentally moved past the correct code, you'll have to start the search again.
    Test the remote. If the code was successful, you should be able to turn the device on and off using the remote. Make sure you've pressed the correct device button at the top of the remote before testing the features.
    Not all functions may be available on the universal remote. Your remote may have limited functionality compared to the device's original remote.
    Retrieve the code. After you've locked in the code, write it down so that you can enter it easily in the future.
    Here's how.
    Press and hold the Code Search button until the light comes on.
    Press and release the device button for the locked code you want to retrieve.
    Press and release the Code Search button.
    Press the number keys in order, starting with 0. When the light comes on, this indicates the first digit.
    Start over at 0 and repeat until you have all three digits.
    Good luck
    David
What is the code for a GE remote
turn device on (tv etc)
hold power and device button until remote blinks
release both buttons
press power repeatedly until device shuts off
when device shuts off push device button on remote to save setting should blink again
press power test that remote operates device
Do someone have a vcr remote code for kaon ksc 570?
Turn device on (tv etc)
press power and test that remote operates device
1helpful
I have a jumbo remote, lost my manual. I would like to program it to operate a sanyo tv. I need instructions please.
First, make sure the device you want to connect with your remote is turned on, whether that's the television, DVD player, VCR player, etc. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the device (TV, DVD, etc.). Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn't recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
If your device code isn't listed, try the Code Search function:
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
The codes to various devices are listed at:
www.remotecentral.com
Please note that there are often several codes for one particular device. It may take several programming attempts until you find the code that works with your device.
5helpful
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
15helpful
Need instructions on how to program a RCA model RCR 3273N universal remote
Hi! There are two ways on how to program your RCA Universal Remote Control. First is the direct code entry. In following these steps you need to provide me the type and brand of the device you want to be programmed to your remote control so I can give you the code for that certain device. Since you did not indicate the information I need for the code I will advise you to do the second way which is the Auto Code Search. Here are the steps for you to be able to program your Universal Remote without the code list.
1. Manually turn on the device you want to control.
2. Press and hold the device key you want to program. While you’re holding down the device key, use your other hand to press and hold the remote’s POWER key at the same time.
3. Wait until the remote’s indicator comes on and stays on. Then release both keys.
4. Point the remote directly at the front panel of the device you want to control. Press PLAY on the remote and wait 5 seconds. The remote is testing a batch of 10 codes on your device.
Did your device turn off?
YES: Go to step 5.
NO: Press PLAY again. The remote tests the next batch of 10 codes.
Keep pressing PLAY every 5 seconds until your device turns off.
5. When your device turns off, press the REVERSE key on the remote
and wait at least 2 seconds. The remote tries the last of the previous ten codes.
Did your device turn on?
YES: Press the STOP key. You’re done! You’ve programmed this device key.
NO: Press REVERSE again. The remote tests the next code in the batch. Keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
Note: If you accidentally press the REVERSE key after your device turns on, press the FORWARD key. Then, wait two seconds to see if your device turns off again.
I have a logitech Harmony 890 remote. The battery
To check to see if your device is controlled by a RF (radio frequency) or IR (infrared) remote:
Power the device on manually
Cover the front of the original remote that came with the device with your hand
Press any button on the remote that you know the device would respond to normally
If the device responds even when your hand is covering the front of the remote, the remote is RF and the device cannot be controlled by the Harmony remote
Another test that can be performed is using digital camera:
Using any digital camera, even one on a cell phone, camcorder or webcam, look through the screen of the camera at the front of the remote
Press a few buttons on the original remote
If you see flashes of light as illustrated, the remote is IR and the Harmony can control it. If the remote does not flash, this original remote is an RF remote and the device cannot be controlled by the Harmony remote
For comparison, try the same steps with a remote control that you know is working correctly, such as the original remote for the TV, or DVD player. You should see the IR emitters flashing when performing this test.
4helpful
2answers
I can't find the code for our tv brand it is a
    Try This Out
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player2.gif, VCR or stereo.
  2. Step 2 Pointthe remote at the device you are programming and press thecorresponding device button on the remote. These buttons are labeled"TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  6. Step 6 Pressthe device button for the component you just programmed, and hit thepower button while pointing the remote at the component. If programmedcorrectly, the device should turn on, and you should be able to controlit with your Living Solutions Universal Remote.
Top NexxTech Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
