Question about Sharp LC-19SB14U 19 in. LCD TV
Tv will not start after power surge
Sharp tv will not start after power surge ( no power indicator light),
How do I test the power suppy board,main board, etc for replacement?
PS -qpwbfe333wjn2,qpxbxe367wjn1,qpwbfe241wjn1
I have a digital multimeter to check outputs. Is there a most likely component or circuit breaker that goes first?
Thanks for any help or recommended repair service contacts.
  • Anonymous Jun 30, 2010
    budmrtn,
    How do I make photo attachments for posting with my service question?
    [email protected]
  • Anonymous Jul 13, 2010
    Bud helped me determine that my Power Supply was not working even after the main fuse was replaced.
    IMPORTANT: I found some power supply boards available for Sharp model number LC19SB25U but not for my Sharp LC19SB14U. Visually PS looked the same,so took a chance by ordering one and found it to be an exact match except for the style of the main fuse!
    Mission accomplished - Tv restored - and is now connected to a surge suppressor - lesson learned!
    Thanks Budmrtn
Bud Martin
  • 11,361 Answers
Voltage checking and caps inspection will be the first thing to do.
If you can post the pictures, that will help a lot. Look at the inverter board to see if you are getting 12~18vdc feeding it, also look for caps with leaking/bulging top.
See some pictures here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jun 29, 2010
Testimonial: "Example pictures quite helpful. I do some more visual checks and then post pictures of my power supply and ask for test locations. Thanks"
  • Bud Martin
    Bud Martin Jun 30, 2010
    Send pictures to my email instead, [email protected].
    To post picture at FIXYA, you use the TREE looking icon on the post sending box, but it is limit to 150k resolution.
  • Bud Martin
    Bud Martin Jul 01, 2010
    Check the MAIN AC fuse (red block) by the AC inlet.
Have a Samsung 65” led tv. Model # UN65H6203BF. LED back light blinks and red status light blinks when power plugged in. Changed Power Supply(used but good), no Change, all still blinks. Can unplug main...
You may have a back lights problem.
To test the back lights, you need to disconnect the cable between the main power supply & the main board, apply the AC power to the power supply, if the back lights are not light up, or blinks, the back light are defective.
Sep 12, 2018 | Samsung Televison & Video
Need to troubleshoot a Sharp 70" LED TV: Symptom: No Picture, not responsive to controls.
Hello Doug,
I would suggest to test all the voltages in the power supply, If all the voltages test OK then It's more likely that the main board is causing the LED not to be responsive.
May 09, 2018 | Sharp Televison & Video
Sharp aquos TV is not working after power surge, how do I fix this?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Aug 11, 2015 | Sharp LC-60LE600U 60" LCD LED TV 1080P
Help new power supply will not power up.
if you had a surge, it could have damaged more than just the power supply. When you plug in the unit, does the power indicator light up??? your main board could also have damage. The main board sends a signal to wake up the power supply thus turning on the TV. If you have to replace the main board as well, it probably won' t be economical to repair the set.
May 19, 2012 | Polaroid FLM-3734B 37 in. LCD HDTV
Sharp AQUOS LC-42D85U tvgos does not work and hasn't worked for several months. What is the problem?
What is ur tv problem?No tv power LED light incation all or power LED light indication an OPC LED lights indication flashing togethers?Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting.Tv might work again.Tv still have no pwer all?Yes.The tv power supply board it is dead,that the board where the power a/c cord plug into it.If the tv have both power LED and OPC LEDS lights blinks together.The tv main board Tuner signal board it is the cause and the problems it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a main Tuner signal board for the replacement.
Jul 03, 2011 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
Had a blackout and now power suppy won't turn on. Green ps light blinks and makes a clicking sound through speaker.Modelatx 300-12z cdr
Surge has possibly fried the PSU. Depending on the severity, you may find other components are damaged on the motherboard.
Best way is to test with a known good PSU
Jan 07, 2011 | Bestec (ATX100-5) (ATX1005B) Power Supply
Sharp LC46SB54U TV will not power on
It can be as simple as a blown fuse in the main power supply module, if you get not indicator light at all, then it will be the power supply has gone out, if you do get some indicator light, the 5v standby power supply is still functioning but not the main section of the power supply module. The filter capacitors look good, no bulging tops?
Sep 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
My sharp lc46sb54u 46 in.hdtv power light keeps blinking
Any indicator light on at all, if you see the light, then only the 5v standby power supply is working but not the main section of the power supply, it can also be the main control board hat is not sending signal to turn on the main power supply section.
Sep 01, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sharp LC-19SB14U 19 in. LCD TV Logo
1,105 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
