Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Where can i get a replacement fuel tank for a reddy heater model TA100,103,106 or 111 ?
Posted by henalonso on
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: Replacing rotor on Readdy Heater
Remove top shell. Remove cover. Remove filters. Remove filter base. Then it should pull out. Check clearance on new rotor .003/.004 checked with feeler gage. Reinstall in reverse order. Reset air pressure. Good luck.
Posted on Feb 23, 2008
Anonymous
  • 61 Answers
SOURCE: Reddy propane heater RLP100
Try a little longer, sometimes it takes a full minute to heat the thermocouple. Check and make sure thermocouple is in flame. If all this is ok. then your going to have to change the valve.
Posted on Nov 30, 2008
tbugger
Jerry Magee
  • 232 Answers
SOURCE: REDDY HEATER 125T WON'T INGNITE
  1. Does the ignitor glow for 5 seconds when the unit is started?
  2. What is the air pump pressure reading?
These are the starting points for troubleshooting a heater that has an ingntor.
Answer these questions and maybe someone can get you started.
Posted on Dec 16, 2008
steve_lima
steve
  • 181 Answers
SOURCE: Reddy Heater R50A will not ignite
yep.plug the unit in and look in the back of unit.should see an orange glow.if you don't the glow bar is not comming on
Posted on Feb 23, 2009
baugh55grfmj
Mitchell Baughman
  • 225 Answers
SOURCE: Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Posted on Jan 05, 2010
I have a clogged fuel line (filter?) I do I remove the bushing without damaging it?
FUEL FILTER
(For 40/55/60/70/110/115/155/165 Models
Only)
1. Remove side cover screws using 5/16" nutdriver.
2. Remove side cover.
3. Pull upper fuel line off fuel filter neck (see
Figure 15 or 16).
4. Carefully pry bushing, fuel filter, and lower
fuel line (110/115/155/165 Models only) out
of fuel tank (see Figure 16).
5. Wash fuel filter with clean fuel and replace in tank.
6. Attach upper fuel line to fuel filter neck.
7. Replace side cover.
Jan 20, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I Have an old M30 REDDY HEATER, It won't start, Good Spark, Good Fan, Clean fuel, Pump has some pressure- I have no-idea on how much is needed, Not sure about the in-out of fuel lines to the Main Jet...
Depending on how old your heater is, you may bay be able to download the Owners Manual from the Reddy Heater Home Page website. Reddy Heater was made by DESA International (now out of business). Another company bought the Reddy Heater part of the business, so they are still being manufactured.
Feb 02, 2011 | Reddy Heater-30-55,000 BTU Variable
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
I can't get my reddy heater to light. No fuel
If there is NO fuel then the pump rotor is probably broken. http://www.reddyparts.com/rotor%20replacement.htm
If there is SOME fuel then set the air pump pressure. http://www.reddyparts.com/pressure.htm
Nov 02, 2009 | Desa International Reddy Heater R40 40,000...
Fuel filter
take the side cover of and you will see where the fuel line goes into the tank. typicall the cap turns clockwise to remove and the filter is hooked right to the cap.
Jan 26, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
My Reddy Heater runs a little then shuts off
Before I went replacing anything, I'd open the right access (looking from the front)panel. Pull the black feed hose off of the nipple on the the filter assembly. Carefully remove the filter barrel, which will be sticking down in the kerosene tank drawing the fuel out.With a flat tip screwdriver, rotate the plastic piece on the bottom of this assembly. Mine is red and looks like a little plug with a screen filter, shaped like a funnel. It has a friction fit so it will not be threaded. Pull this out and see if the fliter has dirt or debris in it. Blow it out with compressed air or wash it with a solvent. Replace the filter and reassemble, plug it in and turn it on. 98% of my early shut down or fuel issues are resolved by doing this. Doesn't take much to restrict fuel flow in these heaters enough to shut them down. Good luck.
Dec 14, 2008 | Reddy R60A Utility Heater
RC150F
http://www.desatech.com/manuals.cgi?oldpro=Construction+Heaters&products=Construction+Heaters&Manual=&Model=RC150F&Type=Show+All&x=75&y=11
Check out this link. There is a detailed owners manual and other info.
Feb 11, 2008 | Reddy R155D Utility Heater
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
796 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
