Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal
memory card is full" there is no more space in the camera's internal
memory. Your camera has 16 MB of internal memory. The number of pictures
you can store depends on the picture size setting you have selected on
your camera. Keep in mind that the
camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Take them back if you can, then start over. Some of the lessor know brands can be defective.Have you tried to use a reader to see what a computer says is on them?
Please check the settings on your camera if it has any option to switch between the internal and external memory card. Probably the internal memory is under selection.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card full message and the card can be used again.
No, copy your music to the memory card rather than storing it on the phone. you must do this in 'My stuff' folder, select 'sounds' select the mp3 then click the bottom left button (details), then press 'file', then 'move'
To view the moved files goto 'My stuff' folder, select 'sounds' then in the top right corner you will see a picture of a memory card. press this to see swith to view the external memory.
