SOURCE: adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
SOURCE: Andis trimmers are making loud noise when used outside US
i have the exact same problem, i bought them with a transformer. I turned them on and nearly deafened me! it is soo loud and when you turn the screw on the side, the noise stops/goes quieter but the blades dont move! If anyone has any solution please helpp!
SOURCE: how di adjust blades to make andis clippers
Take blades off clipper,loosen screws on blade, place on mirror, rest teeth against mirror, angle clipper at 1 oclock position, slowly titen screws
