Saeco V-spresso Espresso Machine Logo
Posted on Jun 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi temperature - Saeco V-spresso Espresso Machine
Anonymous
Level 3:
  • Master 1,089 Answers
  • Posted on Jun 29, 2010
Anonymous
Master
Level 3:
Answers
1089
Questions
0
Helped
520959
Points
4348
Hi
In your menu there is a setting for temperature. You can raise or lower the temp. There is also a cup temperature setting.
West bend slow cooker. What temperature do the numbers stand for?
https://www.westbend.com/support/product-faqs/slow-cookers-crockery-cookers.html
What are the temperatures when set at the Lo and Hi selections?
  • The temperature range reached at Keep Warm - 155-170°F
  • The temperature range reached at LO - 175-185°F
  • The temperature range reached at HI - 200-212°F
WestBend manuals:
https://www.westbend.com/support/user-manuals.html
https://www.westbend.com/support/user-manuals/slow-cookers.html
https://www.westbend.com/support/contact-us.html
1helpful
3answers
Self-cleaning electric range
Hi
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1Safety flip flopReplace Electronic Range Control/Clock (ERC) F2 - E0Shorted keypadReplace Electronic Range Control/Clock (ERC) F3 - E0Oven temperature sensor or oven temperature sensor fuse openedReplace oven temperature sensor or fuseF3 - E1Oven temperature sensor shortedReplace oven temperature sensor F3 - E2Oven too hotReplace oven temperature sensor F3 - E3Clean temp too hot Replace oven temperature sensorF5 - E0
F5 - E1 and E2 Door latch problemCheck door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of yourmodel # 0-5 that will determine which control it takes. Once you havethat # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
What is Error HI?
you didn't mention the model, but on the washer/dryer combo units, the H1 means the following:
Dryer temperature sensor error detected A fault has been detected with the dryer temperature sensor on washer dryer models.
  • Check connections to dryer sensor
  • Check temperature sensor
1helpful
H 1 Flashing
This is actually stating "HI", as in either the refrigerator or freezer, temperatures are Hi and not at a safe level. First, press any button to stop the alarm and clear the HI temperature. If you are still receiving the alarm, I suggest checking the freezer, to make sure that everything is still frozen, and nothing is defrosting as, well as checking the refrigerator temperatures. If things are defrosting or the temperature is Hi in your refrigerator, I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, Give your freezer 24 hours to stabilize at the default temperatures of 0 degrees for the freezer and 37 degrees for the refrigerator.
Temperature display on rsa1rtpn
hi when i minimise the temperature from 17 to -20 the temperature gose back to 17 why. thanks
5helpful
2answers
Fridgeaire error code H1
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
What is the reason for the reset button keep poping out on the dean sm35gm
Hi there!
Reset button of hi-limit switch will only pop-out when its sensing bulb sensed temperature higher tha 450F (trip temperature of hi-limit). Theramostat may be bad allowing oil to reach temp above 450F causing hi-limit to trip-off or hi-limit itself is bad tripping-off at temperature lower than 450F.
Check also the position of the sensing bulb of the hi-limit, it may be positioned touching the heat tube (for gas fryer) or heating element (for electric fryer) that's why it prematurely trips-off.
Regards.
Spa keeps overheating
Faulty temperature sensor should do this to.
A floating thermometer should read water temperature within 3-4 degrees of spa controller. If it is greater than that your sensor is bad.
The hi limit is an over heat sensor it does not control the temperature of the water. If the water is heating above 118 degrees and the spa is not shutting down its Hi Limit.
1helpful
2answers
Hoover oph 714d optima 7kg washing machine fault code e05
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
6helpful
How would you know high limit thermostat is defective. need to know before ordering part
Hi, you'll need a ohm tester (multi-tester) you will have to remove / disconnect wires from hi-limit, in normal room temperature, place tester lead on terminals where you remove wires, if you get a beep/continuity, hi-limit is o/k, if no beep/continuity, hi-limit faulty, for further test you can heat up hi-limit, (oven) and check with tester, hi-limit switch off when temperature gets to high, and switch on when temperature drops, so at room temperature hi-limit should be on, (hear beep on tester), if there's no beep/continuity at room temperature, high-limit is faulty. disconnect power before doing any repairs, good luck.
Aug 29, 2009 • Dryers
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
