Click the Start button ,
click Control Panel, and then
double-click Bluetooth Devices.
Click the device that you want to change, and then click Properties.
Do any of the following:
To change the name of the device, click the General tab, type a new name, and then click OK.
To enable a service, click the Services tab,
select the check box next to the service, and then click OK.
To disable a service, click the Services
tab, clear the check box next to the service, and then click OK.
To make your computer discoverable
to Bluetooth enabled devices, in the Bluetooth Devices
dialog box, click the Options tab, and then select the
Allow Bluetooth devices to find this computer check
box.
To make Bluetooth enabled devices discoverable to your computer,
in the Bluetooth Devices dialog box, click the Options tab, and then select the Allow Bluetooth
devices to connect to this computer check box.
To be notified when a Bluetooth enabled device wants to connect to
your computer, in the Bluetooth Devices dialog box, click
the Options tab, and then select the Alert
me when a new Bluetooth device wants to connect check box.
Warning
To help protect your computer, only make your computer
discoverable when you want a Bluetooth enabled device to find your
computer.
Some computer programs require a COM
port (also called a serial port) to communicate with a Bluetooth enabled
device. For example:
A program that synchronizes contacts with a mobile phone
A program that extracts Global Positioning System (GPS)
coordinates from a GPS receiver
When you use the Add Bluetooth Device Wizard to add a Bluetooth
enabled device to your computer, you create an incoming COM port, which permits
your device to connect to a program on your computer, and an outgoing COM port,
which permits a program on your computer to connect to your device. Usually, you
only need to use one of these COM ports.
To decide which COM port to use, you can check the information
that came with the program or your Bluetooth enabled device, or go to the
manufacturer’s website.
If you're still not sure which COM port to use, try each COM port,
one at a time, and use the one that successfully allows the program and your
device to communicate.
