Dell Wireless Keyboard Optical Mouse w0147 Logo
Question about Dell Wireless Keyboard Optical Mouse w0147
Changing the batteries does not make the mouse work. the cursor is visible on the screen but will not move. what next?
Posted by chasechenowi on
Lynne
    Scholar:
    New Friend:
  • 102 Answers
Have you tried re-pairing your mouse? Should be a button on the bottom of the mouse and a button on the wireless antenna device. Or, If your using a bluetooth mouse make sure bluetooth is turned on, on your computer.
Posted on Jul 05, 2010
Logik LMWLPP13
I would still try changing the battery. Even if the light in the mouse is still visible, the battery voltage may have dropped.
Cursor disappears lenova yoga
Press Fn key and F7 key together
2helpful
How do I connect a microsoft wireless moblie mouse 3000 to my laptop?
Press the button on the back of the mouse to free the battery cover on top.
Remove the battery cover and put the supplied AA battery into the mouse.
Replace the battery cover.
Insert the wireless USB dongle into a USB port on the laptop or desktop computer.
Move the mouse and watch your computer screen.
Confirm that the mouse is connected by making the cursor move.
Hope this helps
2helpful
Mouse cursor jumping problem, how to fix it?
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
1.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
2.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
3.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
2helpful
3answers
My Gigaware optical mouse's cursor won't move
Sounds like the laser failed. Return it for replacement.
Mouse stopped working - cursor won't react
What type of mouse do you have, the brand and the model. Sounds like you need a driver for the mouse you have. If im understanding right you have a wireless mouse?
Microsoft Intellimouse Explorer 2.0 Battery Problem
You say that this has been happening with a wired mouse as well?
In that case, you probably have a kind of virus/malware. Try this first:
http://housecall65.trendmicro.com/
Do a full system scan. You may have to temporarily disable/uninstall your current anti-virus if you have one already..
If not, try a system restore.
1helpful
3answers
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Hope this helps others. My mouse stopped controlling cursor but buttons worked. Problem was it would not work on a black table. Slip a piece of white paper under it and waaala! It works. I'm thinking optical mouse and dark surface might be an issue.
1helpful
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Trouble pairing my bluetooth Macally BT micro mouse
Clive
Clive
Steve Sweetleaf
Steve Sweetleaf
