Doesn"t cool properly. Freezer will only go 2 20 degrees & refrigerator portion only to about 40 degrees.
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the freezer section, look at the back wall- any frost buildup there.
Hope this help.....
Freezer is blowing but not cool.. Ice has melted and items are defrosting..
SOURCE: freezer cooling but bottom refrigerator not cooling
Make sure the cooling fins are free of dust and debris. If not try to recharge the freon supply. If that don't work the compressor might be going bad. Which in most cases it's easier to replace the unit after parts and labor you could be looking at some serious money......Hope that was helpful....... : )
SOURCE: We have a 10.0 cubic
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
SOURCE: My MCBR1020W 10 cu ft top mount
It is a cheap piece of junk. I bought one just this week and the defrost timer gets stuck so it's going back...........
Its defrost problem, the freezer should cool,
then freeze, then defrost cycle should start. In your case freezer is cooling,
then freezing, but its not defrosting. That's why fridge section is not
cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
