Cameras Logo
Question about Sigma 75-300mm f/4-5.6 DL Lens for Nikon AI
Will Sigma 75-300 f/4-5.6 DL work on my rebel XTi
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sigma Master
  • 102,366 Answers
If the lens has a Nikon mount (as you imply in the post), then no, it will not fit. If it has a Canon mount, then yes, it will work fine on your Canon Rebel.
Posted on Jun 28, 2010
Testimonial: "thank you for info, i will attempt to buy."
What adapter do I need for a Sigma AF 75-300 lens on a Canon Rebel XTi SLR?
Question edited for clarity.
You get the Sigma lens for the camera in Canon fit.
https://www.google.com/search?q=sigma+lens+af+75-300+for+canon+rebel+xti
Can you use Sigma lenses on Canon cameras?
Since Sigma lenses are made to be fully compatible with Canon cameras, they are backwards-compatible. This means that you can use a Sigma lens on a Canon DSLR camera. Similarly, the Sigma cameras are backwards-compatible with Canon lenses. Macro adapter loses the AF feature.
https://www.google.com/search?q=sigma+lens+af+75-300+mount+adapter+ring+for+canon+rebel+xti
DS 126151 error
What kind of error? Err 99?
You mention DS 126151, that's the model number. This camera is mostly know as Canon EOS Rebel XTi? Also known as the EOS 400D or EOS Kiss Digital X.
If you are getting a Err 99 while shooting, try any other lens that will fit on your Canon. In most cases the aperture will become defect in these lenses. Not worth repairing if you ask me. One thing you could do, is shoot only at its maximum aperture. So that'll be F4.0 at 70mm and F5.6 at 300mm. That might work, but that might not be suitable in every situation.
8helpful
Does Sigma 70-300mm f/4-5.6 DG Macro Telephoto Zoom Lens fit canon eos rebel
Sigma makes their lenses with a variety of camera mounts. If you get the lens with a Canon mount then yes, it will fit any EOS Rebel camera body. A lens with a Pentax mount, for example, will not fit a Canon camera.
1helpful
2answers
Does a sigma 70-300mm dl macro fits on a canon 500d camera?
Yes, if you get one with a Canon mount. Sigma makes their lenses available with a variety of mounts; a lens with a Nikon mount, for example, will not fit on a Canon camera.
8helpful
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 DL Hyperzoom macro Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts...
To NOT get that error you need to use in AV mode. It's the only way that old Sigmas work with the new Canons. It's an aperture bug that old Sigma lens have and some the only way to fix it is to rechip it. The problem is that Sigma no longer rechips the lens.
Sigma 70-300 AF lense
if the lens is the older type with a macro switch which has 2 screws holding it on to the lens it will not work.If it a super 70-300 you can put the camer on AV set iris to F22 if you have a stopdown button see if the lens stops down it ok if noe it will need a rechip or a new interuper
Sigma 70-300 mm lens wont focus
I was focusing to close to the subject & too much glare from a church window.
Camera lens
Hey kgconstruct,
The lens description that your posting is categorized under is a 75-300 f/4-506 DL lens for Nikon AI. If this is correct then no this lens won't work on a Canon camera. I am assuming this isn't correct and the lens you have is for a Canon camera, and if this is true this lens should work on the XTI. If you’re thinking of buying this lens I would go to a local camera store that carries this Sigma lens and try it out first to make sure you like it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Lens Compatibility
The XTi does not have a "full-frame" sensor, so vignetting should not be a problem with this lens.
Top Sigma Cameras Experts
Steve
David Shaub
Are you a Sigma Camera Expert? Answer questions, earn points and help others
