Question about Maytag Neptune MDE4000 Electric Dryer
The agitators in the drum are loose and I need to know how to get to them to tighten?
Posted by healthman100 on
Anonymous
    President:
  • 1,554 Answers
Those are the drum baffles and the top cover needs to be lifted to the rear of the dryer to access the outside of the drum, but you have to remove the front panel first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly. Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Posted on Jun 28, 2010
1 Related Answer
Anonymous
  • 10 Answers
SOURCE: Maytag neptune model MDE5500AYW loose tumbler in drum
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick pull. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Posted on Apr 09, 2009
How to repair a loose drum?
You need to remove the agitator, loosen the tub nut (May already be loose), align bowl & tighten tub nut.
2helpful
Simpson Encore 605 agitator bolt comes loose - does it need loctite?
The wear is preventing it from tightening correctly, loctite won't be a long term fix, it will still come loose again due to the forces put on the bolt by the vibrations of the agitator. The only way to fix it is to replace the agitator.
Have GE HYDROWAVE WHDRR418G1WW, Purchased two years ago, worked great, now it really bangs when it changes direction when agitating. \r\nBottom pulley is tight and moves around 1/2" before changes...
There might be spider (device that supports drum) which has a bearing in the center of the drum, this bearing might have worn down and might need replacing. Try to put some bicycle oil in the centre bearing and see if the noise reduces, not a permanent solution but a method of diagnosis. With regards to the agitator being loose, try wedging a piece of wood such that the drum does not turn, tighten the center screw and remove the wedge.
2answers
Agitator not working
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
3helpful
Top section of agitator does not turn even though bottom of agitator is working properly. How do I repair?
You may have worn agitator dogs, causing the upper portion of the agitator (called the "auger") to slip. Or, you could have a loose agitator bolt. The following link explains how to replace the dogs (if necessary) and how to access the bolt:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
If you need to replace the dogs, the part number is included. You can purchase them for about $5 at appliancepartspros.com. For a little more, you can purchase the entire agitator drive replacement kit. Look for it under the "Agitator" parts section. You can also reference the helpful exploded view diagrams the site offers for assistance.
NOTE: When tightening the agitator bolt make sure you do not overtighten. This may cause damage to the agitator, or restrict its movement. Tighten until snug.
If you still require assistance, please let me know. I hope this helps you.
On a two piece agitator the top section doesn't work but the bottom works okay.
This problem is usually attributed to either a loose agitator bolt, or the agitator dogs wearing out. The following link explains:
The upper portion of the agitator is called the "auger". If it is loose, simply tighten the bolt under the center post cap. DO NOT overtighten as this can cause damage to the agitator, or restrict motion. Just tighten until snug. If you have questions along the way, please let me know. I hope this helps you.
3helpful
2answers
Need to remove agitator on kenmore series 70
Follow these steps for removing the agitator on a Kenmore:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Sometimes this is a dispenser cup that simply pops off.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Carefully remove the auger (upper portion of the agitator) and set aside.
  5. Remove the agitator by grasping the bottom flange and carefully pulling straight up.
Note: Try to keep all the parts assembled while doing this. In particular, the auger. There are small components inside. In addition, when reinstalling the agitator DO NOT over-tighten the center nut. This can restrict agitator motion and may cause damage. Tighten until snug.
If you have questions, please let me know. I hope you find this information useful.
2helpful
Loose agitator
Remove the center dispenser. Under the dispenser is a plastic cap with a pull handle on it. Pull the cap straight up and you will find a mounting bolt underneath. Using a socket and ratchet, tighten the bolt snug. DO NOT overtighten as this may cause damage to the agitator. If you go to searspartsdirect.com and type in your model number, there is an excellent exploded view diagram of the agitator components under the "Agitator, Basket and Tub" heading. If you still require assistance, please let me know. I hope you find this information helpful.
5helpful
2answers
HELLO, WSL100D0WW IS MAKING NOISE ON DRAIN/SPIN CYCLE.
Or, you have coins in your pump casing. Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Remove and change/objects from the chamber and replace the port. You should be good to go. This is actually very common for this model washer.
2answers
Agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
Maytag Neptune MDE4000 Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
