Tip & How-To about Computers & Internet
Hi... This is Vikas Sharma From M/s Computer Solutions, Patiala - Punjab, India
Im Going to give you one good advice that if you want to make your laptops battery life batter and want that your battery should run and give proper backup then use the battery as much as possible and when laptop shown the message that battry low or less than 5% then charge it back full. do it atleast once in a week.
Acctually the purpose is that when you charge and discharge the battery full all the cells used and charged and discharged. when you charge your battery when it is having i.e. 40% or 30% etc. charging to full and then you use the battery upto i.e. 40% and again you charge it then the remaining 40% cells are not charged and discharged then they become useless and again and again this process dead the cells that are not in charging and discharging position. This is the one big reason for battery problem.
so I suggest that charge and discharge the battery for better results.
Thanks Take Care
