My cbr 600 f2 had been sitting for a long time before i got the carbs cleaned at a shop. It runs fine once it is warm, but its sometimes hard to get started since even with the choke all the way on, the idle revs. sits about 1200rpm or below and sometimes nearly dies unless i open the throttle a bit. Once the bike is warm,(after having turned choke off) if i pull the choke on the rpm goes up to around 2500 but then drops back down almost right away. What could my problem be? thanks!
Well once the bike is warm, and the choke is off, ive played with the idle adjustment knob to get it to about 1250rpm with the clutch in. I was under the understanding that that was normal. Also, what can explain that when i pull the choke on all the way revs rise quickly but then drop right away?thanks for the help!
