Question about Sub-Zero 690 Side by Side Refrigerator
Check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Posted on Jun 28, 2010
Testimonial: "thanks for the help - I will check all your suggestions "
where is the damper located and how can i tell if it is frozen shut
