Question about Frigidaire FAC124 wall/Window Air Conditioner
My FAC104 P1A window air conditioner does NOT drain any water. I don't even see a drain hole on the underside?? Am I overlooking something? Thanks, Jeff
Posted by claatsch on
David Shaub
    President:
  • 2,976 Answers
Some don't have a drain hole anymore. As long as you have it tilted slightly, any excess water will drain out. If your house or room feels good, it's working. It won't pull moisture out of the air if the air has already been dehumidified.
Posted on Jun 28, 2010
Where is the drain pan drain hole on the bottom of the Fridgidaire FAC 127S1A air conditioner?
Good Morning Friend,
I understand you want to know where the drain hole is on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, instead of draining. The drain hole is located beneath the compressor. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire FAC127S1A Air Conditioner
Draining for a Haier Window AC
no, this air conditioner is a manual drainer and is not made to drain itself
Jul 29, 2013 | Haier Heating & Cooling
After running the A/C for a couple of hours and after a period of rain, I took the air conditioner out of the window. Probably one or two pints of water emptied on the floor. there is an open vent on top...
Many of the newer A/C window units do not drain the water, but use the fan to splash it up on the coil to evaporate it and help cool the unit...
You can drill a hole in the back corner to drain it, but watch that you don't hit the coil and cause a freon leak...this also may reduce the efficiency a bit...
heatman101
Aug 23, 2011 | Crosley CA10WXP Air Conditioner
My LG air conditioner is spitting out water and making a weird noise....i took off the front panel and theres a lot of water in what i guess is a condensation pan....ive tried drying the little bit i can...
Go around the back side and unplug the drain hole! These are designed to drain out the back through a hole in the drain pan. Maybe your unit is tipping forward and not draining like it should. You can use a coat hanger or wire or even a shop vac to remove debris from the drain.
Aug 15, 2011 | LG Electronic Window Air Conditioner
It is making a noise like something is in motor or like ice on blade and spitting little drops of water out of front
Becky, from what you described, the AC unit has a buildup of water in the drip pan. This can be caused by 2 things. The drain hole near the rear of the unit is clogged and/or the rear of the unit is not tilted down enough. The general rule of thumb is 1/4" to 1/2" rear downward tilt. This allows the water to flow to the rear of the drip pan where the drain hole is.
Finding the drain hole can be a challenge at times. Because the clog can blend in with the drain hole.
But, patience and persistence will pay off. A pipe cleaner works well to clear the drain hole. nd, don't forget about the downward tilt.
I hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | LG LW1200ER Air Conditioner
Hello, I need the hose to drain water outside that fits the fridgidair portable air conditioner #FAPO9EP1Z1. Is there another small tube or is there any other hoses or vents that I need? I don't see...
impreston - with out the following parts , you really don't have "just the air conditioner."
1- Flexible Exhaust Hose
2- Hose Adapters
1- Sliding Window Kit
1-Foam Window Seal
1-Remote Control
The drain hose is something you supply. A garden hose, no longer than 5 feet will do if you want it to be a continusos drain, rather than drain into the water collectiong bucket. But, without the first 4 items lister above, you won't be able to operate the unit.
Here is a link that may be of some help to you, since you don't have an Owner's Manual.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020252a0373en.pdf
You will beed to contact Frigidaire (1 -800-374-4432 ) for the parts you're missing.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire FAP094P1Z Portable Air...
I have a AW06ECB Window Air Conditioner Unit that is not draining water. It is holding it in the bottom pan. I don't see a drain pipe or hole on the bottom of this unit for it to drain either. Any...
Hello, most window units will not have a drain to remove the condensate. Instead they use the fan blade to sling the condesnate on the condenser and since the condenser is warm/hot it will evaporate it. Also, when the humidity is elevated there will be more water at the bottum of the drain pan.
Jul 10, 2011 | Samsung AW0507M Air Conditioner
On my LG window AC Md. LWHD1009R, I cannot find a drain hole to let the water out. The back bottom of the pan was filled water containing a rusty sludge, but the heat exchanger coils are aluminum, so it...
usually in the middle underside of the window units is a hole that water drains out of, you can always drill new holes in order to make it drain, Good Luck Tim
Apr 24, 2011 | Heating & Cooling
How do istop the tcl portable air con leaking water
As you probably know, Air conditioners condense the moisture out of the occupied space, as the room air passes over the colder coils.
That water has to drain away into a drain, or a bucket -- or something!
So-- How is the water designed to drain away?
and what is interfering with that path?
There are the obvious causes, like mold, or a bug, or dirt, etc-- blocking the drain hole-
Or possibly sediment filing the condensate line trap--
Are you sure these are all clear, and open?
But one that is often overlooked, is the fact that a fan might be creating a slight vacuum in the area where the drain line exits the rain pan--- and the water can actually be prevented from draining, until the fan shuts off (removing the slight vacuum)-- is that possible in this machine?
Or when you open up the machine, is the drain pan still filled to over flowing?
Can you use a mini Toilet plunger on the drain, to help unblock it?
Give me some more clues, and I'll try to help you trouble shoot deeper into the problem.
Mack B
Jan 16, 2011 | Heating & Cooling
Water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Aug 18, 2009 | Frigidaire Heating & Cooling
Frigidaire FAC124 wall/Window Air Conditioner Logo
638 people viewed this question
Top Frigidaire Heating & Cooling Experts
John Tripp
John Tripp
MARLON KELLER
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
