Nespresso Aeroccino Automatic Milk Frother Logo
Posted on Jun 27, 2010
How do I make cold froth on my aeroccino for my lattes?
My aeroccino 3190 starts the hot frothing right when I hit the button. I am not able to hit the button for cold froth. How do I do this? Thanks!
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jun 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4702
Points
8
Press the and hold the button for 5sec or longer until the light turns blue. That will get you cold froth.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Sep 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
12643
Points
12
The 3190 does not cold froth. This is a feature of later models.
Michelle Grillo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 20, 2017
Michelle Grillo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4177
Points
Do you know why when I press and hold I just get a flashing blue light and nothing happens? Thanks!
Ricardo Andrade
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Apr 25, 2017
Ricardo Andrade
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
4177
Points
7
Hello i have an old aeroccino+ and don´t cold , i press more than 2 secs and the light is red
Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Aeroccino frother won't turn back on after we get some froth and still more milk in container.. takes a long time to be able to activate again.. using Almond milk could be the problem any suggeest
My Nespresso Aeroccino often would not heat or froth multiple times after one use. I called Nespresso, they have excellent customer service, and was told to rise the inside (careful not to get the outside button or electric elements wet) of the Aeroccino with cold water a few times and to retry. Works like a charm!
The customer service is the best I have encountered in a long while, give them a call, it will make your day they are so pleasant and helpful!
The frother doesn't froth. I start with cold milk fill it to the hot froth line and push. The red circle lights up and whirls around, but when it stops there is no froth
I have tried tilting mine slightly, just a 20c peice under one edge of the base put enough of a lean on it to make the milk froth. Shouldn't have to do this, I know. I am having similar issues becasue I don't think I should have to alter the unit. Mine is 2 weeks old.
4helpful
3answers
It froth's milk beautifully but won't do soy milk.
We bought a Nespresso Milk Frother in 2010 for $100. The frother is the same one that comes with the Citiz machine but is a stand alone model. It froths soy milk very well. The less soy you put in it, the more froth you get but even if we fill it to the max line we still get a reasonable amount of foam. We use Silk brand soy milk. I have no idea if foaming is impacted by atmospheric pressure but it may be a factor to consider if you are using all the same factors as us but not getting great results. We live at a higher elevation Calgary, Canada in the foothills of the Rocky Mountains.
8helpful
My Nespresso milk frother did not come with instructions. Is there some way to froth but not heat the milk?
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
4helpful
2answers
Aeroccino deosn't make froth
Our aeroccino worked fine for 2 years and suddenly it didn't made foam anymore. We tried the "inverting trick" without much success. We contacted Nespresso and they suggested switching from regular fresh milk (we used 2%) to UHT milk (harder to find in US) and to use it cold and freshly opened. So we tried that and it works.
Hope this solution works for you too
1helpful
Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
3answers
Aeroccino does not heat
Try descaling, if the element is covered with scale it wont produce enough heat and pressure.
The machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Top Nespresso Coffee Makers & Espresso Machines Experts
Kolbrun...
Jay Finke
Jay Finke
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
